What I would like to know is:- Is there any way to save loops and cue points in a song so that next time you play the song you don't have to do it all again manually? If not is this feature planned?
geposted Wed 17 Mar 04 @ 2:33 am
no loops can not be saved with the full our demo of VDJ. I have talk about this befor.
https://virtualdj.com/forum/display.html?topic=2485
geposted Wed 17 Mar 04 @ 4:58 am
As for the cue points, these are automatically saved to the Internal Database, so everytime you load a song the cue points will appear as they were the previous time they were loaded
geposted Wed 17 Mar 04 @ 11:53 am
Saving the loops I think would take away some creativity of the DJ. To me, loops are a vibe thing, just how you feel at the moment and the energy you sense from the audience. It's the same concept as scratching.
What would be more practical to me is the ability to go to the start of a loop at will, in addition to depending on vDJ's FAME engine to have calculated an accurate bar. Traktor does this well and vDJ has the hooks to do it, it's just not implemented. (see command "Goto_Cue[x]")
geposted Mon 22 Mar 04 @ 12:34 am
geposted Mon 22 Mar 04 @ 10:48 pm
ok
first find ur loop position and make a cue there lets say cue 1
then find out how long u wanna loop lets say 8 beats
choose a key lets say Z
then make a shortcut Z as go to cue 1
and again a shortcut Z to play
and again a shortcut Z to loop 8 beats
now any time you press Z it'll play your loop
there you go now you can Save a loop ,,,, with vdj the possibilties are endless ,,,, and again i have surprised my self lol
ps: it would be better to use cue 9 since its the least used cue and everytime your setting your cues use 9 for a loopable part so when ur mixing and u think ur in trouble or late or missed ur cue point hit ur MAGIC Z button and ur in bussiness again
dj smokey very happy with his little idea
geposted Tue 30 Mar 04 @ 5:11 am
“choose a key lets say Z
1-then make a shortcut Z as go to cue 1
2-and again a shortcut Z to play
3-and again a shortcut Z to loop 8 beat
now any time you press Z it'll play your loop”
The shortcut works in the order you put a command in a Z key (1-2-3) And you can add another function after “loop 8 beat” like: play or stop.
Coyote
geposted Tue 30 Mar 04 @ 5:22 am
geposted Wed 31 Mar 04 @ 9:56 am
geposted Wed 31 Mar 04 @ 11:22 am
since cue points are always saved all u gotta do is assign
cue 9 to a loopable part of the song
and when this is done any time u press Z for example u'll get ur loop pretty simple
all u gotta do is assign it one and thats it
geposted Wed 31 Mar 04 @ 11:47 pm
I really don't know how........To
Thank you.
geposted Tue 10 Aug 04 @ 1:20 am
DJ Homeboys Making Shortcuts Tutorial
First select the config button located at the top right. Then Keyboard shortcuts.
Now select add a shortcut.
Choose a key to assign the shortcut to.
The red circle shows the sub menus of shortcuts that can be created.
So select all to view all the shortcuts in VDJ.
The red circle shows all the shortcuts that can be created in that sub-menu.
Now find the shortcut you wish to add. I chose play for example.
The red area shows the last options of this shortcut.
*Selecting momentarily will allow make it so when you press the key for the shortcut created it is only active when you have the key pressed in on your keyboard. When you let the key go the action stops.
*Next you have the ability to assign this shortcut to desk1 (left desk), desk 2 (right desk), default (not playing) and active (playing).
*There is also an auto setting. Info will be displayed in the box directly above it as to what auto settings will do for this action. For "play" if auto is selected it will automatically synch the music with the other track.
That's it ! Hit ok and test the action to be sure it does what you wanted. Remember VDJ see's the actions in order. So if you want a shortcut to be preformed in a certain order be sure to assign them appropriately.
geposted Tue 10 Aug 04 @ 6:40 am
but to brake it down
u tell vdj to do an action and u assign a button for that action
so when u give the same button 3 actions for example it'll do these three at the same time
one little trick to make it easier
c not everybody uses all the cue points so just set cue 9 at a loopable part every time u make cues
and that would make it easier
make ur shortcuts and ur done
ps... homeboy i like ur idea with the momentary and auto i didnt think of that nice one
dj smokey still happy with his little idea :)
geposted Thu 19 Aug 04 @ 6:52 pm
I have recently found or stumbled across an alternative to "loop cue point" by creating a "sample". Tbh, I've only just started playing around with this feature recently, but with more practice, it will only get better and easier. The only trick is "saving" it. Then you can load it on any of the "sample" keys and/or use it at any time, not to just that particular song.
The bonus to this feature is that you can set it to "loop" as well as "beat lock".
Give it a try and let us hear how it has worked for you.
geposted Fri 07 Apr 06 @ 5:25 pm
geposted Fri 07 Apr 06 @ 6:47 pm
Thanks for the heads-up.
I installed it, but it offers no instruction how it works.
I have been unsuccessful in being able to creating a loop, thus saving it, then re-loading it.
Your or any assistance is appreciated :)
geposted Sat 08 Apr 06 @ 12:37 am
So go in your song at the good place: choose the function loop() in the list, then in value 4 for 4 beats,...
then set the cue in the plugin. You have two modes: the first one will only play the loop once as soon as the cue is reached, the second mode will always play the loop when the song pos is on the cue.
Besides, there is an internal system in the plugin to save the cue for the next time you load the song but in addition you can save another config too
I hope it's clearer
geposted Sat 08 Apr 06 @ 2:01 pm
Still was unsuccessful creating my intention (saving/re-calling on-the-fly loop). Can you please simulate my intent and post a step-by-step
Here's what I did:
set a cue point to start/play loop
selected
selected the (1) button which then launched a window of settings
I chose (loop) and beat length as instructed.
chose save w/ file name, then closed.
I selected the FX once again and was unsuccesfull playing re-calling any loop.
After further thought, CuePoint seems to be no different from me setting a cue point and playing a loop (4, 8, 16 16, etc) by a set key stroke, right?
My intent is create specific/manual loop (in/out), save it, and being able re-call it at will, as well as saving it so next time I play the song, I can re-call the loop. I am sure you are aware that at times a created loop may not fit within 8, 16 or even 32 beats and is the purpose of my intent/request. Is VDJ capable of doing this?
Can a "Plug-in" be created to meet my intent?
Oh! not sure if this is a bug or not, but when manually creating a loop (in/out), when I select "reloop, problem is, it starts a new loop at that point rather than playing the "manual" loop I had created. You or a Mod have an explaination?
Btw, the skin I am using is BOANERGES v1.1 (Mackie).
Thanks for any feedback :)
geposted Mon 10 Apr 06 @ 5:59 pm
