Topic: new version 3.3 is available - Page: 2
Yepp - it's a very minor update, almost like a "3.2 SP2".
"my main screen still says v3.2": do you mean on the skin?
He means VDJ's splash screen.
Really? I don't have this problem with the full install
The file I got was a 2-3 megs, after installing I'm still getting 3.2 splash screen. But I did notice that when I went to attempt a second download (to check the file size) the file was like 8mb (lite), strange.
Were there 2 files?
mine was 2-3 megs ... the splash says 3.3 ....the skin however still says 3.2 when you close a panel.
mine is likewise. 2.51Mb....splash 3.3..........skin still 3.2
Nikki
I meant the skin still says 3.2. The splash does say 3.3....didn't notice that at first,
Thanks for the help.
Howard
I think nikki is the first female registered user I've seen on the forums. I think there needs to be more encouragement for the female pop.
Thankx rids. I like to keep all you guys on your toes lol. Keep up the good work guys and keep the vibes alive.
Nikki
I am logged in and there are no available updates for me. WHY?
Its an update for full pro users only.
dont know if there will be one for Hercules... might be.
you mean that just 3.3 is not available for DJC edition or every future update? (3.4, 3.5 ...)
Totyo: Virtual DJ is not a free program, however the version bundled with the Hercules DJC is pretty much a free version dedicated to the console.
Free upgrades are promised to fully registered users of Virtual DJ pro, VDJ's only obligation to the console users is to provide a software free of any major bugs.
See the benefits of upgrading to Virtual DJ Pro:
http://www.virtualdj.com/products/djcedition.html
Being a customer of the console edition you can also benefit from a discount on the FULL PRO VERSION:
http://www.virtualdj.com/purchase/discount.html
Regards.
Listen2; Very good point. I really should d/l the update at least to my desktop.
all 3.3 has done is fix problems so i think it will be avainlable to HDJC MkII users. and if its not it should be
(C)opyright Atomix Productions 2005 at the bottom of every page, are they gonna change it or what?
Have a day off Xeo.., lool.
maybe atomix is using Julian calendar :-)
I will buy pro. it's pretty cheap (I have console + internet buy)
98%
