what's up with this? I downloaded the trial version onto my desktop and it loaded about 24 different icons. 2 VDJ trial icons, and a whole lot of other stuff. I know what some of it is but...DAMN!!! how do I clean all this up and still make vdj work?
NEED HELP & ADVICE
FAST FAST FAST like RIGHT NOW !!!
If it's not too much to ask
Thanx
NEED HELP & ADVICE
Thanx
geposted Sat 07 Jan 06 @ 1:17 am
what did you do, if you recognise some of it it wont have been put there by the VDJ installer will it lol. dont know aht youve done but just save it somewhere else incase its improtant to clear up your desktop lol. how strange
geposted Sat 07 Jan 06 @ 1:36 am
Hey Xeo, All the icons are for vdj but...DAMN.... 24 icons? The installer can't put everything in a folder? Is it all needed? How do I clean it all up? where do I put it all? Do I have to leave anything out on the desktop for the program to work right?
HELP?!?!??!!!
HELP?!?!??!!!
geposted Sat 07 Jan 06 @ 1:46 am
I just counted. It's not 24 icons. IT'S 28 ICONS
geposted Sat 07 Jan 06 @ 1:50 am
just delete all the icons that you dont want or put them into a folder. they will still work perfectly as they are only links.
by the sound of it somthing must have gone wrong in the install because there is only ment to be six (and there in the start menu). theres only ment to be 3 on the desktop. virtualdj, ripvinyl & ripdvd
geposted Sat 07 Jan 06 @ 1:56 am
I got folders...
1. Effects
2. Playlists
3. Skins
4. Video Translations
5. Music
6. Samples
7. Video Effects
I got Application Extentions (dll)...
1. dirac.dll
2. DashHard.dll
3. D-Vinal2020a.dll
4. D-Vinal2020b.dll
5. lame_enc.dll
6. Scrstch_Backwards chops.dll (I have 2 of these)
7. Scratch_Forwards Chops.dll (I have 2 of these also)
I got xml's
1. Shortcuts_defualt
2. Shortcuts_nuo4
3. Shortcuts_old
4. Shortcuts_vc33
5. xp10
I got standard icons...
1. Ripdvd
2. Ripvinal
3. Virtualdj_trial
4. Virtual dj Trial
I got applications...
1. Unwise (This is the uninstall)
And I got the text docunent...
1. Install
Is all this needed and is it all supposed to be all over my desktop?
1. Effects
2. Playlists
3. Skins
5. Music
6. Samples
7. Video Effects
1. dirac.dll
2. DashHard.dll
3. D-Vinal2020a.dll
4. D-Vinal2020b.dll
5. lame_enc.dll
I got xml's
2. Shortcuts_nuo4
3. Shortcuts_old
4. Shortcuts_vc33
5. xp10
1. Ripdvd
2. Ripvinal
3. Virtualdj_trial
4. Virtual dj Trial
1. Install
geposted Sat 07 Jan 06 @ 2:19 am
Haven't you chosen another directory to install VDJ as the default one is c:program files ?
geposted Sat 07 Jan 06 @ 2:28 am
I put all the Icons in a folder xcept for the dvj icon. I tried to open vdj and got an error message
"Invalid skin file (error line % in the xml)"
geposted Sat 07 Jan 06 @ 2:29 am
djcel...What do you mean? I'm nwe to computers but a long time dj.
geposted Sat 07 Jan 06 @ 2:30 am
lol
you installed the program to your desktop.
first uninstall using the shortcut.
then reinstall and choose 'c:/program files/virtualdj' as the install directory and allshould be good
geposted Sat 07 Jan 06 @ 2:31 am
Probably you installed it to c:\\Documents and settings\\djcity\\desktop instead of Program Files ????
Or as usually something got screwed up in those WindBlows :-(
geposted Sat 07 Jan 06 @ 2:32 am
Whoa 3 posts while I posted mine :-( got to go to bed, am to sloooow noooow..zzzzzzzzzzzz
geposted Sat 07 Jan 06 @ 2:35 am
djzero...Im gonna try it again. I'll get back to ya and let u know how it went.
geposted Sat 07 Jan 06 @ 2:37 am
DAT'S WUZ UP !!!!! It worked.. THANK YOU FOR ALL YOUR HELP!
I did not mean to double post. Didn't realize that by posting here and in the software tech forum would be double posting. Just wanted the answer and to inform whoever needed to know if a possible problem existed. But... It was all my fault.
geposted Sat 07 Jan 06 @ 3:05 am
Ok, now at least you know that it's here only one great community but the communication is spread over the several subforums to have some sense. Problems are in problems/support forums and whoever has problem or sees somebody having a problem he can help with will use it.
Nice day to all.
Nice day to all.
geposted Sat 07 Jan 06 @ 3:13 am
