It is important how you choose the title for your submission.
If it's not clear/interesting many people just ignore it.
Here are some tips that will help You and other users to avoid chaos in forums.
Anyway before posting you should also try a search function and look for similar topics, that probably relates to your problem/question.
Bad: "Help, please"
-There are many posts like this each day. Many prefer to ignore it and your call for help gets lost in history. Try to shortly describe your problem.
Bad: "Problem with programme"
-There are more versions and also many hardware. If you know that you have problem with MAYA and it previosuly ran. Something like
Good:"No sound from maya USB after upgrade VDJ3.1->3.3"
Bad: "Will this work"
Good: "Will VDJ work with Numark DXM01 and TCCD ?"
Bad: "Which to choose?"
Good: "Numark DXM01 or Ecler NUO?"
Bad: "Hello, I got a problem. Till this morning my PC was ok, but after I turned it off and the back on in the evening, vdj won't start. Can you help? Thank you all for help!"
-Even in this case try to keep it short and to give a sense. More details in the body of message.
Bad: "CDplayer with mp3 ????????????????????????????????????????"
Bad: "===!!!=== Buy hercules or behringer ???? ===!!!==="
- Please clean up your keyboard, or don't fall asleep at the PC with your nose holding the key.
Bad: "WHICH VERSION TO BUY?"
- Don't shout, ehm, don't write all uppercase it's difficult to read and can be reason for someone to skip your post.
Bad: "Plz ppl need hlp with da cool soft. Thiz babe not runnin dudez."
- Many users are not native english speakers and/or probably not like the slang/street style. Try to speak/write clean it's more understandable. And the vision of reading the whole post in the same style is spooky.
@Webstaff , probably it's good idea to create some rules, and put it somewhere under the "Unread TOPICS, together with search :-)"
Bad: "Help, please"
geposted Wed 18 Jan 06 @ 3:47 pm
I'm with you lopez453
geposted Wed 18 Jan 06 @ 7:09 pm
I agree...also...don't ask for a serial number!!!
You will get this when you buy the program!
P
P
geposted Wed 18 Jan 06 @ 8:42 pm
