Topic: two questions
hey,I just got my new timecoded vinyl in the mail. I am very happy about that. I am wondering can you wash the tcv with soap and water like you can with a normall piece of vinyl? Also are you supposed to regester your vinyl? If you are how?
Thanks
geposted Tue 14 Feb 06 @ 1:00 am
Man-TkPRO InfinityMember since 2004
Yes you can ....they are like normal vinyls
geposted Tue 14 Feb 06 @ 1:06 am
geposted Tue 14 Feb 06 @ 5:45 pm
listen2PRO InfinityMember since 2005
you just got them ...did they ship dirty? :) I would use something like gruv-glide.... soap can leave behind a film, some use rubbing alcohol 70% but i think that can be too harsh on vinyl. Maybe watered down some more. But honestly they are made for controls not keeping mint, just use them. I use only one side at a time so it kind of makes 4 copies not just 2.
geposted Tue 14 Feb 06 @ 6:16 pm
djcityPRO InfinityMember since 2005
Just a suggestion....DO NOT USE SOAP
Your tcv should be fine unless you live in a dust tunnel. I kinda doubt you do.
just take a clean soft cloth like terrycloth and wipe the dust off the vinal if needed.
Just don't use the tcv to eat off of and don't use them as dustpans and you should be fine.
lol
listen2 has given you some good tips in tcv care. I am just having fun with you. :-)
if you need anything...don't hesitate to ask. we are here to help
DJ CITY
geposted Tue 14 Feb 06 @ 9:57 pm
can someone helpme please?
i bought the maya 44 usb sound card and oi tried using it to let me use my time code vynnls on vdj byt i am only able to control one side so basicaly my 4 in put and 4 out put sound card is acting like it has 2 inputs and 2 out puts how can i fix this or configure it to see all my channels
and another thing can you record you video mixes just like the audio ones?
geposted Tue 14 Feb 06 @ 10:01 pm
Dj XeoPRO InfinityMember since 2005
in settings go to sound cards, then low latency timecoded vinyl, then make sure you have the correct options selected in there (left =1&2 right = 3&4 not master = 1&2)
and yer i would use an ioniser cloth or pad to remove dust from the surface of the reccord (especialy if you dont have covers on your TTs or put them back in their sleaves) if your vinyl surface is starting to look very dirty with a collage of finger smudges then soap (real soap not the pump ones, they have all sorts of hand softening and fragrance etc that your vinyl just doesnt need) a lean mixture of washing up liquid in warm water is good but the most preferable is WD40 (never used it myself but i have heard people rave about how it cleans out the groves of those classics lke noones business.) if your gonna use soap etc make sure you rinse after and dont just let the residue dry on the vinyl.
geposted Wed 15 Feb 06 @ 12:52 am
it still doesn't work it only picks up input channels 1&2 and out put channels 1&2 how ever teh asio4all picks them all up and that is what i am running the maya 44 throught
are the tcv supposed to have grooves in themlike a regular vynnl cuz i don't think mine has any and soteh needle moves around.
geposted Wed 15 Feb 06 @ 4:42 pm
NEVER MIND I FIGURED IT OUT
geposted Thu 16 Feb 06 @ 7:43 pm
