Topic: Can someone help? =]
GallioHome userMember since 2006
Well I just downloading the trial version and it keep saying:
VirtualDJ will not try to connect to the internet and check if a new version is available
You can disable this action in the CONFIG menu at any time.
I'm not really sure how to disable that can someone direct me to the right place, I'm also sorry if this is in the wrong section.
geposted Sat 11 Mar 06 @ 11:34 pm
mp3jrickPRO InfinityHonorary MemberMember since 2003
Click "ok" and the program should open up.
Then click config in the top right corner and go to general tab.
3rd from the top "auto update", click enable and it will change to disable.
geposted Sat 11 Mar 06 @ 11:51 pm
Hm, Its odd because after I click ok nothing happens. I've uninstalled and reinstalled twice. Do you think I'm going something wrong apon install?
geposted Sat 11 Mar 06 @ 11:54 pm
Did you get the install link from this site or somewhere else on the net?
geposted Sun 12 Mar 06 @ 12:03 am
I got it from this site (aka Download.com) I'm not at all sure whats going wrong, I'm very good with software but this is puzzling me to the extreme.
geposted Sun 12 Mar 06 @ 12:34 am
erxonPRO InfinityMember since 2003
Try disconnecting from internet before starting the program. Might do the trick.
geposted Sun 12 Mar 06 @ 10:16 am
djcityPRO InfinityMember since 2005
Something else you can do if nothing else helps.
Direct your issue to the support team. I am certian they can help you.
Let us know hou you get along.
geposted Mon 13 Mar 06 @ 1:15 am
What resolution is your system set up to run?
geposted Thu 16 Mar 06 @ 2:53 pm
JeremKPRO InfinityModeratorMember since 2004
If your screen is in 800x600 VDJ won't open.
You need to be in 1024x768 minimum.
geposted Fri 17 Mar 06 @ 12:55 am
