Forum: VirtualDJ Skins
Topic: problems with skins download
hi all,
I have problems with the skins.....when I download the file instead of a zip one I get a htp.....what is the problem.
Thanks
geposted Thu 30 Mar 06 @ 4:33 pm
install the skin in the "skin" folder in the VDJ directory from install
no is not working....the file should be a .zip (at least itwas like this for te older versions)
what version are you using??? you download it, click open and it automativly installs it. If you saving the file then try saving it in the skins folder.
If you are using firefox or another internet browser that isn't Internet Explorer, the skin download could possibly not work.
Try again with Internet explorer, it will download a .exe file and then it will install in Virtual DJ folder.
perfect, now is working. I was using Opera, now I downloaded it using explorer.
Thanks a lot
