In the Mix Station skin, what does the "Auto Scratch" button do and how do you use it?
What does the "VTC" button do and how do you use it?
geposted Thu 20 Jul 06 @ 5:03 pm
auto scratch will mute a direction, for example you can mute backwards playing which makes for easy crossfaderless stabs, you can select which type of "auto scratch" you want in the options. VTC is just another TCV button that will activate or deactivate timecode mode.
geposted Thu 20 Jul 06 @ 5:57 pm
