Hi everyone just wanted to share a shot of virtual VJ it will be released once version 4 is out
Full res in my blog.
geposted Fri 04 Aug 06 @ 3:32 am
New Screen shot today :)
geposted Fri 11 Aug 06 @ 4:40 pm
1024 x 768 WoW, that skin is looking HOT.
geposted Fri 11 Aug 06 @ 6:26 pm
Hi,
it looks v. good,
Is there going to be a 1280x800 versionof this skin by any chance?
it looks v. good,
geposted Mon 14 Aug 06 @ 1:50 pm
the skin can be maxed to any res, I'm coding it on a 19 in wide screen I choose 1024 so everyone can use. New screen shots in my blog today.
geposted Mon 14 Aug 06 @ 4:00 pm
It's looking great
geposted Mon 14 Aug 06 @ 6:01 pm
geposted Mon 14 Aug 06 @ 6:57 pm
Ok vmix4 is on the downloads page however your going to have to wait till V4 is released to use it. http://www.virtualdj.com/addons/skin.html?id=2134
geposted Fri 18 Aug 06 @ 8:00 pm
I LOVE THE SKIN GOT IT WORKING IN VERSION 3.4 BY REMOVING RHYTHM SCRIPT FROM THE XML TO SEE WHAT IT WOULD LOOK LIKE COOL
geposted Sat 19 Aug 06 @ 1:54 am
doesnt really look the same in 3.4 , much better in ver. 4
geposted Sat 19 Aug 06 @ 4:26 am
I cant load the Vmix4 i receive a error "invalid skin file (error line 60 in the xml)"
what a hell ????
somebody help me
ps: im using the last version os virtual dj ( 3.4 )
thanks
Dee Vj Viny
what a hell ????
somebody help me
thanks
Dee Vj Viny
geposted Sun 20 Aug 06 @ 9:11 pm
the skin is for version 4
geposted Sun 20 Aug 06 @ 9:41 pm
The Skin is for VDJ 4.0 IT WILL NOT WORK IN VDJ 3.4
geposted Sun 20 Aug 06 @ 9:43 pm
thank you
geposted Tue 22 Aug 06 @ 6:57 pm
Hi,
sorry but i doesn't work with Virtual Dj 4.0 :
When i launch the .exe of your skin , i've an error message "VirtualDJ not found"
Same for the new DAC3 V4 skin
VirtualDj4.0 work and is well installed. And i've had more success with the CDJ1000 plug in for V4.0 !
geposted Thu 24 Aug 06 @ 12:45 pm
had the same problem...
how do you install this skin in Version 4?
geposted Thu 24 Aug 06 @ 1:16 pm
same problem here
geposted Thu 24 Aug 06 @ 7:18 pm
ive got virtualdj4 installed in a seperate directory to vdj3.4
this skin finds the right virtualdj and puts itself in the right skins folder, however...
when i select the skin, i got error in line zero
so i took the files out of the zip file and it worked..
great skin, but i dont use an extenal controler, just need a play/pause button putting somewhere on this skin :)
geposted Thu 24 Aug 06 @ 10:48 pm
The installer has been corrected 4 or 5 hours ago :)
geposted Fri 25 Aug 06 @ 2:04 am
there is a stop and play button on the skin, the timers are, count up is stop count down is play. Turn on tool tip to find many hidden buttons like this.
geposted Sun 27 Aug 06 @ 2:16 am
