Hello,
i've problem with your skin installer (Vmixv4 and DAC3)and VirtualDJ 4:
i got this message :
"VirtualDj software not found. YOu must Install VirtualDj first. Please check on www.virtualdj.com"
geposted Thu 24 Aug 06 @ 3:53 pm
Just a guess, not at home to try it right now.... but have you installed it to say a different location than the default c:\program files\Virtual Dj... (perhaps in an attempt to keep version 3.4???)
Probably not that tho !
geposted Thu 24 Aug 06 @ 5:18 pm
I've got the same problem.
Tried installing it from different locations, same message.
When I had 3.4 installed I had no problem installing it but just couldn't use it
Peace out,
Funkmasterfrank
Montreal
Peace out,
Funkmasterfrank
Montreal
geposted Thu 24 Aug 06 @ 5:22 pm
I have contacted Cyder on this at the show.
He will look at it as soon as the internet cafe is up/available.
geposted Thu 24 Aug 06 @ 5:33 pm
I will recompile the skins as soon as possible
geposted Thu 24 Aug 06 @ 9:58 pm
Fixed!
geposted Thu 24 Aug 06 @ 10:21 pm
Thanks to me for the new script lol
geposted Thu 24 Aug 06 @ 10:43 pm
Thanks to both of you
geposted Thu 24 Aug 06 @ 11:02 pm
Yes thanks to you cel for the new script but thanks to me, because i told you what to change in the script to make it work with V4 ;)
geposted Thu 24 Aug 06 @ 11:32 pm
