@Tanzi:
Well i'm going to have a beer anyways, it's allmost weekend!
i'm sure the dev-team will get it right in version 4.1 i still have good faith the dev-team, they fix things very well. they always do ;)
cheers
cheers
geposted Fri 06 Oct 06 @ 12:53 pm
Just wait and see
geposted Sat 07 Oct 06 @ 8:48 pm
Tanzi maybe not all the fuctions you want will be available for version 4.1 but everything is step by step in order to make it work correctly, I'm pretty shure that for version 4.2 most people will be glad, regards.
geposted Sat 07 Oct 06 @ 10:37 pm
ss DJCEL an me said:
let's wait and see!
let's wait and see!
geposted Sun 08 Oct 06 @ 1:16 am
Might I offer my humble services if you want another tester; my BCD 2000 is currently gathering dust and I would much rather put it to use
DJ Marcel
DJ Marcel
geposted Mon 09 Oct 06 @ 1:01 am
Well, 4.1 was finally released, asio and wdm drivers 100% stable, let's see waht else...
geposted Mon 09 Oct 06 @ 2:46 am
This is my first post on this forum. I've worked with VDJ v2 and v3 in the past - although with mouse & keyboard at a friend's house. very impressed with the software. I just baught a BCD2000. Is there any word on if it is finally working well with v4.10 or 4.11? if I download the demo, will I be able to use the controller? what do I have to do to make it work?
you were saying it worked in v3.4? how can I get it to work in that version?
thanks - pending sale if its working finally :)
geposted Sat 14 Oct 06 @ 2:18 am
http://www.simtel.net/product.download.mirrors.php?id=98165
Try before you buy ;)
Demo is for 4.1, fully working for 20days.
And read this forum on how to set it up :)
geposted Sat 14 Oct 06 @ 2:26 am
well i got the demo, but I can't find instructions to set it up for BCD2K ..... :(
thanks for your help Norway - I'm glad you guys have direct interaction with your customers.....
geposted Sat 14 Oct 06 @ 2:37 am
I'll post a full guide tomorrow (need to consult the BCD vip users first to make it best possible)
But short guide:
- Make sure BCD2000 is in B-DJ mode (Behringer control pannel)
- Enable the BCD2000 inside VDJ at the controller tab in configurations
- Choose the BCD2000 at the soundcard tab
- Go to performance and set the performance slider about middle
- Choose latency AUTO (important!)
- Try safe mode on and off, and overclock on and off (will act differently on different PC's)
If you experience a freeze or lock-up at the console, incease the asio buffer, at the BCD control pannel.
The Behringer asio drivers are very sensitive, so will try to post a tweak guide tomorrow, for those who need ;)
But short guide:
geposted Sat 14 Oct 06 @ 2:42 am
so you're saying all this fuss about VDJ not working with BCD is all resolved in 4.1 completely? I can use the BCD's internal sound card for monitors and MIC?
geposted Sat 14 Oct 06 @ 2:59 am
Monitor Yes / Mic NO
VDJ is not able to Handle an ASIO-Mic yet.
Hopefully in the near future ?! *lookingatnorway*
Have a nice Day
Tanzi
Have a nice Day
Tanzi
geposted Sat 14 Oct 06 @ 3:29 am
Norway told everyone on the Xylio site that they were not going to add mic support. Go over there and read what he said.
geposted Sat 14 Oct 06 @ 3:42 am
digitalmj, it's not quite truth
it was told that:
1. behringer promised WDM microphone support
2. after one users suggestion to support asio microphone and not break the TCV
it comes out that probably there will be 2 options, to use TCV, or use BCD2000 microphone input. But nobody promised that. Norway only said that from this new point of view dev team could reconsider the asio mic support
it was told that:
geposted Sat 14 Oct 06 @ 5:26 am
@digitalmdj
mic will work for future versions all you need is to be patient, dev staff is working hard on it, as you can see even xylio has assumed that they have problems with native drivers, you should consider that bcd is a new product and in order to make it work properly, we need to advance step by step.
geposted Sat 14 Oct 06 @ 5:40 am
That isn't what Norway said over on the Xylio bcd2000 forum. You need to go read it yourself.
geposted Sat 14 Oct 06 @ 1:00 pm
ok, since you got it wrong, I'll say it again :
- Virtual DJ did not intend to support Mic in asio at this time (it MIGHT be added later). But for now VDJ has only , and will only, work with mic in WDM mode. This have been from the beginning...
- ASIO mic support was posted by dev team that there would not be time to add for 4.1, but maybe later.
- Mic will work in Virtual DJ as long as WDM mode is supported. The BCD2000 does not support this yet, but Behringer have promised new drivers, to add mic in WDM mode.
So, in one way or the other, Mic will most likely be supported for BCD2000 real soon ;)
Hope that helps Digit DJ ;)
geposted Sat 14 Oct 06 @ 1:14 pm
Norway let me quote you from the other day. So everyone can understand the whole story.
( ASIO MIC is NOT a part of VirtualDJ, and never will be! Asio inputs are reserved in VDJ for timecode signals, and we do not want to mess up the system by adding support for mic input at same inputs. Now, Virtual DJ DOES support mic in WDM mode, and as soon as Behringer have updated driver to support that (promised by Behringer), the mic will work in VDJ. )
This is what you said and it's there for everyone to read. You do know that most companys don't support the mic in WDM if they have asio drivers don't you?
geposted Sun 15 Oct 06 @ 3:46 am
Dev staff wrote :
just a quick note about mic: mic is not going to work with asio in vdj, at least not in the next few updates. The reason is, we can make vdj compatible with the bcd, but we're not going to rewrite a software completely dedicated for the bcd. That's Xylo's job (and they get paid for that, we don't). Right now vdj only handles mics through wdm, and we're not going to rewrite everything just because BCD's wdm driver doesn't work.
So, ASIO mic is not going to be supported! At least not in next few upgrades..
Nothing is ruled out forever, maybe someday.. maybe not.
But WDM mic is what VDJ supports, and what Behringer should fix....
geposted Sun 15 Oct 06 @ 4:06 am
"Mic support" in bcd....
Mates, you need a solution and you need it now.
First of all, not the best solution even if this will work sometime.
If you are serious about mic just get a real mixer, even a cheap one.
Bcd, hercules and all these consoles are just controllers, NOT real mixer inside.
You got the point.
You got the point.
geposted Sun 15 Oct 06 @ 7:40 pm
