Well it turns out i couldnt wait any longer for 4.0 so i went out and boug SSL. Ive been using 3.4 with some minimal problems but wanted better. I just downloaded 4.0 this morning and have been using it for about 2 hours now and alls i have to say is SSL is going on ebay!!!!!
Great job guys Keep up the good work!!!!
geposted Fri 25 Aug 06 @ 2:02 am
Maybe I'm silly, but what's SSL?
geposted Fri 25 Aug 06 @ 2:10 am
Serato Scratch Live.
Good choice clor, VDJ in my opinion is just as good if not better than SSL.
geposted Fri 25 Aug 06 @ 2:13 am
Thought so...
geposted Fri 25 Aug 06 @ 2:23 am
I bought it thinking it would be great and it really wasnt. It doesnt detect BPM's, You have to to do it externally. And it doesnt support WMA files so i converted all of them to mp3 but it dont matter now.
I sat and tryed everything that used to crash 3.4 with 4.0 and it wouldnt crash!!!
geposted Fri 25 Aug 06 @ 2:26 am
Good to hear;)
geposted Fri 25 Aug 06 @ 3:13 am
Not everyone has problems with VDJ 4. LOL :)
geposted Fri 25 Aug 06 @ 3:23 am
nope! I have ABSOLUTELY NONE problems with VDJ4 ;)
I wish all could be as happy with VDJ4 as I am ;)
WORKS FEAKIN PERFECT;) amazing upgrade... Thanx STEPH! and Atmoix! Just got back from gig, and the sound was smoking, features rocking..... solid, smooth... perfect...
Just wish all could find their perfect setting in the performance tab inside VDJ.
Thats what its all about ;) Find your setting for your pc, and it should run smooth and fine ;)
geposted Fri 25 Aug 06 @ 3:27 am
Please tell me you bought SSL a while back and not just a day or so before 4.0 was being released. I love v4. Everything's been fine with me, and you cant say anything bad about a free upgrade. :)
geposted Fri 25 Aug 06 @ 5:54 am
And V4 is compatible with some features of SSL:
-SSL crates (virtualfolders)
-Serato soundcards
-Serato soundcards
geposted Fri 25 Aug 06 @ 10:48 am
Did I understand that right? You can use VDJ4 with the Serato box???? That should sound WKD.
A
A
geposted Fri 25 Aug 06 @ 12:12 pm
yes-)
geposted Fri 25 Aug 06 @ 3:28 pm
Yes you know the thing that the Serato dev team wanted to make for their soundcard well VirtualDJ dev team makes it before them so now it's compatible ;-)
So which dev team is the best lol
geposted Fri 25 Aug 06 @ 9:32 pm
Im going to try to run v4.0 with the ssl box tonight and see what the outcome is
geposted Fri 25 Aug 06 @ 9:51 pm
-Serato soundcards
-Serato soundcards
Works fine with the SL1..
But how do I get my crates into VDJ then eh?
geposted Fri 25 Aug 06 @ 10:45 pm
