By what means can I capture (record) my video mix'z using VDJ ???
geposted Thu 31 Aug 06 @ 11:13 pm
Not yet at the moment. Maybe there will be possible once ;) You have to use external software or hardware to do that.
External HD video recorder is great choice.
geposted Thu 31 Aug 06 @ 11:23 pm
would a screen recorder software work?
hmm.. would be interesting to try... anyone? ;)
geposted Thu 31 Aug 06 @ 11:35 pm
Can Sony Vegas 6.0 capture from an internal source like the onboard video card ???
geposted Thu 31 Aug 06 @ 11:37 pm
i tryed only with external HD recorder. it makes perfect recordings ;)
geposted Thu 31 Aug 06 @ 11:51 pm
Already did this a long time ago, FRAPS is the name of the software.
geposted Fri 01 Sep 06 @ 12:06 am
I used Camstasia studio and it worked too.
geposted Fri 01 Sep 06 @ 12:09 am
cool ;)thanx
geposted Fri 01 Sep 06 @ 12:12 am
When I used fraps it only recorded 30 seconds at a time though, not sure if there is a way around this, maybe someone on here knows how to make it record longer?
Another program I've tried was Capture Pad 0.1 beta, which is freeware, however, I could never get it to capture VDJ video [I did make other screen captures though so it does work, just not with VDJ when I run video], it seemed to crash every time, but it might be stable for some people :).
If you have any kind of video IN on your PC [TV card, USB A/V capture device etc.] then, probably, the best way to capture VDJ video is to feed your 2nd screen output [from your video card] back into your PC through the video-in device and record direct from there [on the PC you run VDJ on] using any supplied software or free video capture software [such as windows movie maker].
geposted Fri 01 Sep 06 @ 4:51 pm
How can I remove that Virtual DJ bitmap tag found @ the lower right hand corner ???
geposted Fri 01 Sep 06 @ 4:52 pm
In the config/options, under video, theres a check box for 'hide logo', just check that :)
geposted Fri 01 Sep 06 @ 5:32 pm
The Demo version is limited, but if you buy the full edition, all limitations are removed ....
geposted Fri 01 Sep 06 @ 6:42 pm
Thanx!!!
geposted Fri 01 Sep 06 @ 6:43 pm
No problem, cheers for the info about fraps :)
geposted Fri 01 Sep 06 @ 11:47 pm
yea fraps iz hot!! n for tha money n what u can do...;-). I think Fraps n Vdj Pro r the best purchases i've ever made for my dj'in since when i swiched over to cdtt's ..hehehe
geposted Tue 12 Sep 06 @ 8:17 pm
I'm using RiverPast Screen Recorder.
geposted Tue 12 Sep 06 @ 10:09 pm
http://software.sdecnet.com/
see SyncView...
see SyncView...
geposted Fri 15 Sep 06 @ 7:30 pm
