Forum: VirtualDJ Skins
Topic: Pitch Slider disappearing.....
Is this a bug? When the pitch slider is set to the top and you change or reload a skin, the fader disappears.
Having looked at a few skins (including V4 default skins) we have found that this behavior only appears if the slider is NOT panneled...
When loading a skin where the slider is set to a pannel (ie our DAC3 skin) the problem does not occur.
Can anyone shed any light on this?
DJ Mykel
DJ Format
geposted Sun 24 Sep 06 @ 3:04 pm
listen2PRO InfinityMember since 2005
yes i think you may have found a bug but i dont think that would ever really be an issue, i think the panel just helps refresh the slider.
geposted Sun 24 Sep 06 @ 4:12 pm
DJ FORMATPRO InfinityModeratorMember since 2003
Thanks for that. We don't really think that it is a problem to most users, but we like to try to make sure our skins are as error free as possible. If this is a program error then I am sure it will be fixed by the geniuses at Atomix. If it was a skin error we would be tearing our hair out trying to fix it, lol.
DJ Format
DJ Mykel
geposted Mon 25 Sep 06 @ 11:00 am
