Topic: NEED HELP GETTING STARTED - Page: 1
rowl3yPRO InfinityMember since 2006
Hi guys i bet you get this message all the time..
But im looking to start up..
At the mo i have TEC's 1200 MK5 but kinda crap numark groove tool needle's
Looking to setup with a USB soundcard of somthink it i can plug in to LAPTOP and PC..
I really need the USB Soundcard that will work 100% with virtualDJ..
And also this need to be really cheap if anyone could sell me on in UK or any UK link's
Please could you give me INFO on where to buy and what to buy please..
Thanks very much
i see the U46DJ but that like £200 :( need way cheaper please help
OR a PCI card of cheaper
thanks
geposted Thu 07 Dec 06 @ 7:23 pm
sbangsPRO InfinityMember since 2004
the the mk2 homedtion + midi mixer + soundcard
all in one :)
geposted Thu 07 Dec 06 @ 7:24 pm
Hmm where is this package ??
u ave mixer just need software and soundcard
thanks
geposted Thu 07 Dec 06 @ 7:29 pm
Sorry i have mixer
geposted Thu 07 Dec 06 @ 7:30 pm
then get a 4.1 or 7.1 souncard and pro vdj
geposted Thu 07 Dec 06 @ 7:48 pm
hmm i have a tihnk i have 1
geposted Thu 07 Dec 06 @ 8:20 pm
4.1 but how an i gonna conect 2 deck's and 2 out put's 2 a 4.1
geposted Thu 07 Dec 06 @ 8:21 pm
ok come to think of it u need a udj46
or use the mk2 as a cheaper option
geposted Thu 07 Dec 06 @ 10:31 pm
ok where can i get a udj46 for very cheap in the UK and also
what is a MK2
thanks
geposted Fri 08 Dec 06 @ 3:29 pm
Laos im looking at the U46DJ
and is the ESI Maya 44 PCI 4x4 Audio Interface
better for the time coded vinyl's and that
what the best optionion to get i wa t it ruuning sooth and fast
geposted Fri 08 Dec 06 @ 3:36 pm
geposted Fri 08 Dec 06 @ 6:54 pm
is the MK2 a sound card like i can plug my deck's in to in and that ?
geposted Fri 08 Dec 06 @ 8:04 pm
yes and its got a midi mixer for controling virtual dj on it aslo
geposted Fri 08 Dec 06 @ 8:09 pm
so let me get this right
the midi mixer will be able to Plug mu Both decks in to in and use time coded vinyl's back thort my mixer ableing me to mix mp3's like vinyl's
and it will be all in time needle drop and everythink like a proper ct vinyl
thanks
geposted Sat 09 Dec 06 @ 2:12 pm
DJ FORMATPRO InfinityModeratorMember since 2003
YES
geposted Sat 09 Dec 06 @ 6:01 pm
listen2PRO InfinityMember since 2005
if your looking more to scratch mix you might want to check out the virtual vinyl package soon, it includes soundcard,software, and the timecodes (vinyl/cd's)
not that i have the mk2 but i have heard the driver does not provide the best latency desired for fast scratches. What you will get from the mk2 is a basic verson of vdj and midi mixer which would be cheaper but it sounds like you want to scratch with your 1200's
geposted Sat 09 Dec 06 @ 7:26 pm
maybe it would be good for you to get virtual vinyl from numark when it comes out
geposted Sat 09 Dec 06 @ 9:29 pm
ok i have just ordered my vinyl from here with my mate c card :D
Also i was looking to get the mk2 but if what u saying its slower and everythink.
i wanna be able to scrach fast mixng mp3's like im mixing them on vinyl #
this is what i want
and i think by the sounds of this i need a esi u46dj
as the mk2 slower
geposted Sun 10 Dec 06 @ 8:48 pm
works alright for me ;)
geposted Sun 10 Dec 06 @ 8:51 pm
So all i really need is 2 line's in and that will be fully OK just to conect my deck's up to to use for the VDJ
There is no need for a preamp on the lines or anythink ??
thanks
geposted Tue 12 Dec 06 @ 7:21 pm
91%
