Hello,
I have a Maya EX5 external soundcard
First I used BPM studio but now I was testing VDJ and now I hear with VDJ and also BPM studio CRACKLES/POPS when I'm playing a ballad.
There's a big list on this forum about these problems but I can't find the solution.
Can somebody help me.
This is my configuration:
Naam van besturingssysteem Microsoft Windows XP Professional
Versie 5.1.2600 Service Pack 2 Build 2600
Fabrikant Microsoft Corporation
Systeemnaam LAPTOP
Systeemfabrikant Acer,Inc.
Systeemmodel Aspire 1350
Systeemtype Op x86 gebaseerde pc
Processor x86 Family 6 Model 10 Stepping 0 AuthenticAMD ~796 Mhz
BIOS-versie/datum Acer 3A18, 21-10-2003
SMBIOS-versie 2.3
Map van Windows C:\WINDOWS
Systeemmap C:\WINDOWS\system32
Opstartapparaat \Device\HarddiskVolume1
Landinstelling Nederland
Hardware Abstraction Layer Versie = "5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)"
Gebruikersnaam LAPTOP\Administrator
Tijdzone West-Europa (standaardtijd)
Totaal fysiek geheugen 512,00 MB
Beschikbaar fysiek geheugen 153,00 MB
Totaal virtueel geheugen 2,00 GB
Beschikbaar virtueel geheugen 1,96 GB
Ruimte voor wisselbestand 1,03 GB
Wisselbestand C:\pagefile.sys
Systeemnaam LAPTOP
SMBIOS-versie 2.3
geposted Mon 11 Dec 06 @ 10:59 pm
geposted Mon 11 Dec 06 @ 11:01 pm
Performance - under MASTER TEMPO Try Selecting FAST
geposted Mon 11 Dec 06 @ 11:03 pm
Did everything I could from the manual but still the same problems.
Even when I start bpm studio, still hear crackles.
Did everythinh I could.
Any suggestions left?
Please help me If you can
geposted Tue 12 Dec 06 @ 12:58 am
Read this guide from M-Audio:
http://www.virtualdj.com/forums/57349/General_Discussion/Pop__Click__Skip_and_USB_audio_dropouts_solutions_for_PC_s_in_general.html
Please pay special attention to the IRQ parts
ALSO VERY IMPORTANT :
- TRY SET LATENCY FOR AUTO IN THE VDJ PERFORMANCE TAB!!
This fixes issues with more pro soundcards, because this uses the internal latency for the card
geposted Tue 12 Dec 06 @ 1:37 am
hello again,
Thanks for all the help !!!
I did EVEYTHING the manuals tells me to do about cracking.
Then I saw something about the wireless pci card, that maybe this could be the problem.
Did not help.
Then I downloaded the latest Asio drivers for my Maya EX5.
Now BPM studio plays everything without any cracking but Virtual Dj with the Asio driver didn't work at all.
I'm spending more then 10 hours to get this fixed, but now I don't know anymore.
Strange that bpm studio with the Asio drivers works perfect but not for VDJ.
Another point for the future:
Make NO difference when I want to search for a song like "pump it up" or Pump it up"
With VDJ I don't see the same when I search somethin with a p or P
In BPM studio all the words are with capital letters.
That's easier to look at.
BPM studio saves a playlist of all the songs you played.
So far Ican see VDJ makes a playlist and save them from the songs you selected.
And if someone have an idea to solve my cracking problem: Be my guest !!!
Did not help.
geposted Wed 13 Dec 06 @ 12:09 am
Set AUTO for latency inside VDJ performance tab...
And lower the performance slider until you have good sound
Turn off savemode, and try overclock on and off (works different on different pcs)
geposted Wed 13 Dec 06 @ 1:09 am
Thanks for your help dj-Norway.
Gonna try this evening if it helps.
geposted Wed 13 Dec 06 @ 7:50 am
i use system mechanics 6 pro to set my pc remove any startup programs ect... it helped speed up the loading time and removed some skiping that i had :)
geposted Thu 22 Feb 07 @ 9:18 pm
gota be so careful with that program mistakes will mess ur pc up majorly
geposted Thu 22 Feb 07 @ 9:58 pm
yeah absolutely, if you don't know what you are doing make a restore point ASAP! i was technician in a radioshak and we used this prog to restore speed/health to pc's;)
geposted Thu 22 Feb 07 @ 11:15 pm
Or you can just use a program like End It All. It works great for getting rid of services that don't need to be running, you set it up once and just kill the programs before opening VDJ and works a charm.
geposted Thu 22 Feb 07 @ 11:36 pm
