Topic: so much trouble - Page: 1
does anybody own the u46 dj with tcv?
if u could help me out, here is my problem, i am trying to scratch with the tts and the software takes like 2 seconds to react to my scratches, wich makes fast scratching imposible
here r my pc specs,
hp computer with 1 gig of ram amd 3800 plus processer, i dont do video, so if anyone could help me out with this problem, and get it to react as soon as i put my hand over the record, that would be great!!!!!!!
so people please help me, i am desprate!!!
geposted Mon 01 Jan 07 @ 9:39 am
djcelPRO InfinityModeratorMember since 2004
So verify your latency
geposted Mon 01 Jan 07 @ 11:34 am
listen2PRO InfinityMember since 2005
what are your settings?
try latency in performances set to auto (if its not already)
then look for ASIO settings in sound options it will open the u46 asio panel, set that at 128
geposted Mon 01 Jan 07 @ 2:50 pm
as always:
SET LATENCY TO AUTO IN VIRTUAL DJ!!!
geposted Mon 01 Jan 07 @ 5:39 pm
sbangsPRO InfinityMember since 2004
aparently he tried that and no joy :(
geposted Mon 01 Jan 07 @ 5:43 pm
yeh i tryed that
geposted Mon 01 Jan 07 @ 5:50 pm
Ait :
- SAFE MODE OFF ?
And if so, go check USB IRQ sharings.
geposted Mon 01 Jan 07 @ 5:52 pm
hes using the asio 4 all drivers , il get him using the right one
i belive this is the source of the problem
geposted Mon 01 Jan 07 @ 5:59 pm
dont use asio4all with u46dj....
Use the native drivers.
Look in sofware forum for the u46dj driver update thread, and try the latest drivers
geposted Mon 01 Jan 07 @ 6:08 pm
how do i check for irq conflicts????
geposted Mon 01 Jan 07 @ 6:50 pm
k im gettin lil mad here, updated to the lastest drivers, and no i cant get a signle at all on any of the decks, please help me out ppl, please!!!!!!!!!!!!!!!!!!!!!!!!!
the latency is offel, cant scratch at all!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
geposted Mon 01 Jan 07 @ 7:37 pm
could you please post screenshots
of your proformance tab
soundcongig and
timecodecofig
using www.tinypic.com
please
thanks
geposted Mon 01 Jan 07 @ 7:44 pm
man, you're barking down the wrong path here...
Just loose the asio4all drivers, and use U46dj own drivers that came with the install Cd.
Set latency to auto, and it works...
geposted Mon 01 Jan 07 @ 7:49 pm
woof woof
geposted Mon 01 Jan 07 @ 8:01 pm
ok how do i get red of the asio 4 all then????
geposted Mon 01 Jan 07 @ 8:19 pm
control pannel > uninstall
then choose u46dj as your driver in the sound config
yes but asio 4 all came with soundcard, that wont uninstall any other drivers will it????????
geposted Mon 01 Jan 07 @ 8:24 pm
geposted Mon 01 Jan 07 @ 8:29 pm
I have a suggestion......
This will only work under one circumstance though...
it riaa preamp turned on in your tcv settings?
if so, turn it off, and that should fix your problem...
autoconfig turns it on by default, and it says it has 100%, but when you try to scratch, or cue, it takes literally a second to react.... Turn off riaa preamp, and adjust your silence, and you should be spot on accurate.
I had a similar problem, and this fixed me....
I I can't use preamp, or the tcv is slow as molasses...
let us know if this helped you at all...
-Steve
geposted Mon 01 Jan 07 @ 9:22 pm
80%
