Topic: xp10 vs. time coded vinyl - Page: 2
about the cue of Timecode CD's (and looping for timecode CD's) I think there will be a fix for that in future versions of vdj ;) as of now, the timecode use is first of all for timecode VINYL, and the "non-skip" feature for vinyl makes some strange effects for timecode CD use.
But future versions might have the option for turning off the "non-skip" feature for cd use, so that it works like it should ;)
dj in norway
geposted Tue 21 Sep 04 @ 1:49 pm
If I use the time code for the cd option, can I use any cd player with jog wheels? The cd players don't have to support mp3s, correct?
geposted Thu 23 Sep 04 @ 9:35 pm
HomeboyPRO InfinitySupport ManagerMember since 2003
Correct. The cd time coded cd is just like the vinyls.
geposted Thu 23 Sep 04 @ 9:55 pm
With the time coded cds, are you able to plug the headphones into the mixer and cue up the songs or do you have to use 2 sound cards and cue up through vdj?
geposted Sat 25 Sep 04 @ 8:52 pm
