Forum: Old versions
Topic: Video Window???
Video Window???
Is there a way to not display the Windows Bar at the top of the Video window??
geposted Wed 14 Mar 07 @ 11:53 am
djcelPRO InfinityModeratorMember since 2004
Yes use TV output in the video pannel of VirtualDJ
geposted Wed 14 Mar 07 @ 12:38 pm
sbangsPRO InfinityMember since 2004
make sure you have enabled the second screen on windows display options, and then you will see your graphics card apear as an option under window choose this and it will be full screen on that monitor:)
geposted Wed 14 Mar 07 @ 1:10 pm
I don’t think I’m explaining myself clearly…
I add a Video to the player,,, Video window opens,,,, The video window is has the Microsoft Bar at the top of the Video window.. The same spot you find the minimize, maximize and close buttons are..
Is there a way to hide the bar???
geposted Wed 14 Mar 07 @ 9:38 pm
mainedjPRO InfinityMember since 2006
The problem that I run into is:
I enable the nvidia 7600 in the video tab, after enabling the 2nd screen on my desktop. When I switch from the sonique plugin, it doesn't show the music video, and when I open the video up again, it shows it full screen on my laptop too, and I can't see the program to work with it.
geposted Wed 14 Mar 07 @ 9:51 pm
yes use fullscreen output dont use the window option.
geposted Wed 14 Mar 07 @ 9:55 pm
I do under stand,,, in Config,, video settings,, video output,,, tv output pull down I only have (window) to pick from
geposted Wed 14 Mar 07 @ 10:05 pm
that would mean that the second monitor is not enabled or VDJ isn't seeing it as enabled. You re saying you can drag the window to the second screen, but VDJ doesnt see that second screen?? Try setting your main monitor to 1024X768 and your second monitor to 720X480. That is the settings I run unless I am using VMIX 5.2 skin then it is 1280X768 and 720X480.
geposted Thu 15 Mar 07 @ 3:16 am
