VirtualDJ DJConsole edition v3.4.1 is now available in download center for all DJConsole MK2/MP3 registred users. This version is Vista compatible.
Drivers for Hercules needed (firmware/driver update)
For the Hercules MK2 (the one with included soundcard) :
ftp://ftp.hercules.com/pub/webupdate/DJMk2/2007_CMK2_2.exe
For the Hercules MP3 (the one without a soundcard) :
ftp://ftp.hercules.com/pub/webupdate/DJMP3/2007_CMP3_1.exe
geposted Wed 14 Mar 07 @ 4:33 pm
Am still having problem even after installing the patch the error was about DirectX pls I need help am using it with Hercules Mk2
geposted Thu 15 Mar 07 @ 1:31 am
Me too....
I am becoming less and less of a fan of Vista every day now.
geposted Thu 15 Mar 07 @ 2:30 am
I hope get some result before the end of the month because i have a show then
geposted Thu 15 Mar 07 @ 2:39 am
try to disconnect ALL usb device and connect to the pc only djconsole.
The usb conflicts could be cause this kind of error.
geposted Thu 15 Mar 07 @ 9:06 am
Yes I did that and still the same problem I think it's vista
geposted Thu 15 Mar 07 @ 9:38 am
loganfield wrote :
Me too....
Me too! Sucks!
geposted Thu 15 Mar 07 @ 1:40 pm
i will be testing this tonite on my vista systems.
geposted Thu 15 Mar 07 @ 2:05 pm
I was psyched to see the download available for the MK2 version software today and guess what... DirectX sound driver error??? I tried to uninstall reinstall both the software and drivers multiple times but no luck... I even tried upgraded DirectX.... I even got rid of DirectX to see if that would do anything.... Now I reinstalled everything from scratch and still the same deal... Not sure if the wifi or something else on board the computer could be interacting... Yikes... Okay well I will get back to trying some more things...
geposted Fri 16 Mar 07 @ 2:23 am
Install the software as administrator on Vista
geposted Fri 16 Mar 07 @ 2:46 am
Do I need to uninstall again and then install as administrator??? I just tried to reload it as a admin with taking out and that did not work... It appears that the driver for the MK2 is working correctly but for some reason as soon as I go to run the software for VDJ the directx sound driver comes up and nothing can be done.... I looked for a way to configure the VDJ under properties hoping that maybe I am setting up something wrong... Oh boy well tomorrow is another day... I need to catch some zzzz's
geposted Fri 16 Mar 07 @ 3:12 am
yes install as admin so all the nessary files are installed
geposted Fri 16 Mar 07 @ 11:35 am
any good reports?
geposted Fri 16 Mar 07 @ 1:36 pm
sorry not yet , been preparing for my bbc radio interview :)
geposted Fri 16 Mar 07 @ 2:44 pm
practicing yer shameless plugs ????? try not to be nervous just cuz the whole WORLD will be listening
geposted Fri 16 Mar 07 @ 2:58 pm
interview at BBC???
geposted Fri 16 Mar 07 @ 2:59 pm
been hacking again im afraid lol =D
geposted Fri 16 Mar 07 @ 3:29 pm
hi there can someone offer some advise on how to use this software on vista, it was running fine on xp, i dont really care about bbc interviews i care about being able to use my virtual dj with vista...............im getting mad now
geposted Fri 16 Mar 07 @ 5:22 pm
Any success??? Anyone??? I am going to be leaving work soon so it would be nice to go home and get my VDJ up and running with my MK2.... I still think the directx problem may have something to do with a set up issue... Maybe I need to set up something using Traktor first???
Okay well if anyone got it working let the rest of know... I am hoping that since so many people have not reposted that they have their units up and working..
Dave..
Dave..
geposted Fri 16 Mar 07 @ 6:57 pm
First make sure that the console's firmware has been update correctly ( check in DJ Console MK2 Mixer in section About). You should normally get 13.7 or 13.6 depending on the console release.
Finally have something working...
From Hercules:
The firmware update should normally be launched automatically at the end of the installation, but there seems to be a problem there.
To proceed , launch the application ( HDJUpdater.exe) in Program Files/ Hercules/Audio/DJ Console Series/ MK2/Updater/HDJ2Updater
- Uninstall Virtual DJ AND the DJ console drivers, then proceed as follow:
1- Install the drivers first, as Administrator ( right click on the EXE, select "Run as Administrator")
2- Once the installation is complet and the computer as rebooted, proceed in the same manner for Virtual DJ
From Hercules:
geposted Sat 17 Mar 07 @ 12:28 pm
