go download it. tell me hoe it is. im at work
geposted Wed 28 Mar 07 @ 12:37 pm
I've just downloaded it, but I can't see anything that's changed!
(oh, apart from the mac version being there!)
I guess it must be just internal stuff mainly, hopefully they'll update the history soon. :)
geposted Wed 28 Mar 07 @ 12:43 pm
if you are using 3x
use the full install
if you are using 4x use the update from
here
http://www.virtualdj.com/update.html
here
Yes, waiting for the HISTORY to be update too...
geposted Wed 28 Mar 07 @ 12:45 pm
i can tell that the database is better. i think it reads the tags for bpm now which is great
geposted Wed 28 Mar 07 @ 12:46 pm
To start:
the bug with the end of the timecode signal was corrected ;-)
More later lol
More later lol
Hey Cel- Will download it in a little.
So now when the timecode signal ends, the music doesn't end? Thanks!!!
Do you klnow if anything was changed with midi? I remember Nor saying there was some improvements here- ex. Able to control more video effects paraameters with midi now?
not sure if this happened.
thank you.
B
thank you.
B
geposted Wed 28 Mar 07 @ 1:07 pm
Exactly ;-)
geposted Wed 28 Mar 07 @ 1:12 pm
Hi!
Everyone can now play long music files, 74min... Great work it works realy fine i´m just playing two song at the same time (2x74min)and it working wery well. To reduce memory set MAX LOAD in your setings to 5mn.
Virtual DJ Is the BEST!
Best regards
/Karrobarro
Best regards
/Karrobarro
geposted Wed 28 Mar 07 @ 1:19 pm
WHAT A PRESENT FOR MY BIRTHDAY!!!
THANKS ATOMIX
THANKS ATOMIX
geposted Wed 28 Mar 07 @ 1:29 pm
THANKS ATOMIX
THANKS ATOMIX
Happy birthday!
geposted Wed 28 Mar 07 @ 1:46 pm
This could be just me, but on first testing with 4.3 on my non show system, I get the second video freezing, then unfreezing in a random state. Then after loading another track, the new track's video keeps getting stuck, and the previous one stops getting stuck. this is in both the preview windows and in the "Live window".
Anyone else getting this?
geposted Wed 28 Mar 07 @ 2:04 pm
And new for VDJ V4.3 Clear Database.
great work everyone has done in the version 4.3.
THANKS ATOMIX
DJ FORMAT
![](http://i60.photobucket.com/albums/h18/djformat/Image1111111115.jpg)
THANKS ATOMIX
DJ FORMAT
geposted Wed 28 Mar 07 @ 2:10 pm
Hi!
I´m so happy! Erverythin working realy great. I just vanna thank the great work everyone has done in the version 4.3. ATOMIX TEAM IS THE BEST!
/Karrobarro
/Karrobarro
geposted Wed 28 Mar 07 @ 2:12 pm
Soooo... does this mean we can expect VV within the next days/week? Want those tcv's and soundcard allready!
geposted Wed 28 Mar 07 @ 2:50 pm
Please tell me the camera plugin has been fixed too! pretty please....
geposted Wed 28 Mar 07 @ 4:25 pm
@ Format .......is that mix lab 1.2 ? in the pic ....
i'm very concerned that they are going to be pre occupied with all things mac .......i'm happy for the mac and/or vinyl guys but a lotta basic recordcase improvements got pushed to the side
cstoll's xmltool still not in there........
geposted Wed 28 Mar 07 @ 4:29 pm
No the skin is mix lab V1.3 comming soon lol.
And believe me when i say the recordcase has not been put aside,it will be with us soon enough. It will be worth the wait.
DJ FORMAT
DJ FORMAT
geposted Wed 28 Mar 07 @ 5:05 pm
Can anyone post what's new in 4.3
geposted Wed 28 Mar 07 @ 5:19 pm
Why would I want to clear the database?
I am using 4.2 with no problems. What are the advantages of 4.3?
Thanks. CM
Thanks. CM
geposted Wed 28 Mar 07 @ 5:52 pm
