Forum: Old versions
Topic: SINCE UPDATEING TO 4.3 VDJ CAN CLOSE
i don't know if anyone geting this probelm every time i try to close out of VDJ it will not close hung up my pc
geposted Tue 24 Apr 07 @ 7:43 pm
J-SnipPRO InfinityMember since 2006
That's strange. I'm not having this issue. *knock on wood*
geposted Tue 24 Apr 07 @ 9:12 pm
NoizZPRO InfinityMember since 2006
I am having all kinds of issues with the program crashing and everything. I thought that software was supposed to get better with Updates. Who dropped the ball here ? ?? ? Features were not addressed, they were taken away.! ! what's up with that ? !?! ?! !? Now, I can't get the newer version to load the visuals..... grrrrrr.. someone really needs to pull things together ! ! ! !! ! !
geposted Tue 24 Apr 07 @ 9:28 pm
listen2PRO InfinityMember since 2005
backup your shortcuts and database 1st but you might want to try deleting VDJ completely off (including reg entries) and starting with a fresh install.
NoizZ your issues could be related to a million things, why not post your problems and include your hardware/pc specs and config/settings used so someone can help you.
geposted Tue 24 Apr 07 @ 9:56 pm
toshiba satellite 1.6ghz pentium4 512mm of ram xp home sp2 now it's closeing but now it won't load songs it take so long to load a song i went to the store and came back and still loading a 4mints song,i'll try a fresh install and see what's up with VDJ version 4.3 i hope they r not makeing this software too hungry for ram and cpu
geposted Tue 24 Apr 07 @ 11:35 pm
I would update your ram to at least 1 Gig. I run my systems with 2 Gig.
geposted Tue 24 Apr 07 @ 11:52 pm
that's the max the laptop can take 512 the software should not give all this problem like loading a song may be they need to take this out in the software where the songs has to load,i try everything put it on always also on none and still giveing problem to load songs
geposted Wed 25 Apr 07 @ 12:09 am
