How can I fade out the video and audio at the same time (with Midimixer) ??
I have still found no Shortcut for it.
Does somebody have an idea?
geposted Tue 26 Jun 07 @ 1:21 pm
in options on the video tab enable link video and audio crossfader
and then map the controler to the audiocrossfader to control both :)
geposted Tue 26 Jun 07 @ 3:38 pm
I work with it.
But I would like to fade out the video with the Linefader. Without video, without audio ! I need a blackscreen. Can you understand what I mean?
Sorry, I cannot translate it into English so well.
geposted Wed 27 Jun 07 @ 3:45 pm
I think i know what you mean. I don't think it's possible at the moment though, you can only fade from one deck to the other. You can't just fade to black.
The only way you could do this would be to use the "Light Fall" transition, but only move the fader half way. Then you will get a black screen.
http://www.virtualdj.com/addons/download.html?addon_id=1294
geposted Thu 28 Jun 07 @ 2:02 am
Yes that´s right. I need a black screen without audio. But it does not seem to function differently.
With the "Light-Fall" is a good idea.
Thank you for your help.
geposted Thu 28 Jun 07 @ 11:31 am
Did that work for ya??? I believe we did somethin different a few months back where we needed a black screen and all we did was make a black image and used it in Sonique without it on slideshow mode.
geposted Thu 28 Jun 07 @ 11:37 pm
You can use the video transition "Light Fall" + the plugin "Crossfader Curves" (with the curve "V")
geposted Fri 29 Jun 07 @ 12:45 am
It functions for me well. But better fade-out with the chanelfader would be like with a videomixer.
Thanx for your help :o)
geposted Fri 29 Jun 07 @ 1:10 pm
