I just bought the BCD2000 it was a let down because of the mike and it keeps locking up VDJ. so botom like what is the best controller that VDJ works well with?
geposted Sun 08 Jul 07 @ 11:50 pm
Numark Total Control
or
Numark DMC2
Close second:
PCDJ DAC3
or
PCDJ DAC2
or
Numark DMC2
Close second:
PCDJ DAC3
or
PCDJ DAC2
geposted Mon 09 Jul 07 @ 12:15 am
Suppose it depends really on what you want to do with the program.
Marcel is right...NTC and DMC2 are kicking ass just now apparently. I personally use a DAC3 which is great for what I want.
Choice is yours. What do you want to do with the software?
Cheers...and keep spinnin'...(",)
P
P
geposted Tue 10 Jul 07 @ 1:44 am
I second Dj Marcel, Numark Total Control really rocks. If you don't want to get in the hassel of mapping and programing midi controllers then NTC is the best choice, is easy to set it up, no drivers to install, only plug the USB Cable and you are set to go.
geposted Tue 10 Jul 07 @ 6:25 am
I use either the DAC 2 and/or MK2. I like the MK2 cause of the soundcard but on my other machine I use the DAC 2.
geposted Thu 12 Jul 07 @ 12:03 am
The TC rocks, and so does the DJ i/o soundcard. Man this is a nice combo! ANd the DJ i/o has a mic input!!
geposted Thu 12 Jul 07 @ 12:39 am
