geposted Sun 19 Aug 07 @ 5:10 pm
more here:
http://www.videoediv.net/vj-loop/
(thanx to Tex for the URL)
A small note :
The ClipBank video plugin uses VirtualDJ internal encoder, and if the internal decoder can't decode the video, it will try Windows Media Player encoder.
So if you encounter black image or problems using downloaded video loops, download a codec pack such as this one :
http://ffdshow-tryout.sourceforge.net/
geposted Sun 19 Aug 07 @ 5:12 pm
Wow Rooney those look sweet. Makes me want to run out and buy a projector and jump into video.
geposted Sun 19 Aug 07 @ 5:39 pm
By the way. the top posted video loops are generated between users (some digital ecological weird thing).
So there will be NEW video loops to download constantly... from the page at top
geposted Sun 19 Aug 07 @ 5:53 pm
So unless you open your computer to Bittorrent - you can't down load these? Yikes!
geposted Sun 19 Aug 07 @ 8:53 pm
torrents? lol
they are simpy mpeg files that can be downloaded directly from the site above
geposted Sun 19 Aug 07 @ 8:57 pm
The downer is that you cant get them all in one go, click the thumbnail you like, this will open in a bigger picture, right click the bigger picture and select "save target as" and you will get the mpeg loops.
One...... at........ a......... time................ s...l...o....w.......
geposted Sun 19 Aug 07 @ 9:17 pm
Yeah having that problem too...
Perhaps we should all work as a team and download certain ones then zip them and swap lol
geposted Sun 19 Aug 07 @ 9:32 pm
I'm having trouble getting them to display - I downloaded that codec package and - no go.
geposted Sun 19 Aug 07 @ 9:41 pm
You shou;ldn't need to download a codec, they are only mpegs. Do they play for you in mediaplayer?
geposted Sun 19 Aug 07 @ 9:51 pm
nope
geposted Sun 19 Aug 07 @ 9:53 pm
Try this Marcel, should fix it :-
http://www.free-codecs.com/download/Stinky_MPEG_2_Codec.htm
geposted Sun 19 Aug 07 @ 10:01 pm
Can AMBIENT VISUALS from Promo Only be added and used in this new Clipbank?
thanks,
B
thanks,
B
geposted Sun 19 Aug 07 @ 11:51 pm
Yes sir I just added 200 of them. A tip from Dj in Norway, you can have more than one clipbank. Simply copy the clipbank.dll from my documents/virtual dj to the desktop and rename it clipbank2.dll and put it back into the folder you just copied it out of. I have like 6 clipbanks.
When you rip the promo only ambients change the .vob to .mpg
geposted Mon 20 Aug 07 @ 12:15 am
Okay got it.
Trouble was that I was re-naming the file and for some reason it didn't like it.
I re-downloaded a couple without re-naming them, worked just fine.
Thanks guys.
Thanks guys.
geposted Mon 20 Aug 07 @ 12:28 am
OKay Now that I have this plugin working
I LOVE THIS.
It totally rocks
Great Plugin
Crongrats to whomever made it,
I LOVE THIS.
It totally rocks
Great Plugin
geposted Mon 20 Aug 07 @ 12:34 am
geposted Mon 20 Aug 07 @ 12:42 am
Thanks for the links. I would have to advise that people don't download every video plugin that's available on these sites though. The webmasters of these sites probably don't expect the hundreds (thousands?) of people that will read this thread to download all of their loops; the amount of bandwidth this would take would be enormous.
The work on the sheepserver site is allowed to be copied and redistributed, I would advise that some download all the loops - say who you're going to be - and then upload the works in a zipped format (use store, you won't get any compression benefits) to sites such as rapidshare, megaupload and whatever else is popular these days. These sites are designed to deal with large volumes of traffic.
I've compiled a direct download list of all the video loops available from the sheepserver site, for such usage. Using a download manager you should be able to import the links and it will download; although I've not tested the links, I just assume they will work by looking at the websites source.
http://rapidshare.com/files/50038321/video_loops.txt
geposted Mon 20 Aug 07 @ 12:49 am
Thanks Andrew, you saved me a lot of time with this list ;)
geposted Mon 20 Aug 07 @ 1:27 am
