Is it me or is the text 2D box getting cut out at the bottom when placed on most skins that I use.
It seems to require a large "bottom-half" of a skin. When not large enough the bottom part of the text 2D box doesn't show the "apply and activate" buttons. As they are the first thing that gets cut out and the plugin can't be used without those two lil feature buttons?
Please guide me someone in the right direction so I can start using this operation (text 2D).
geposted Wed 22 Aug 07 @ 8:56 am
What skin are you using?
geposted Wed 22 Aug 07 @ 11:08 am
Yes i am aware of this problem but i don't have time to correct it for the moment
geposted Fri 24 Aug 07 @ 11:49 pm
