Forum: VirtualDJ Skins
Topic: FLOOP DJ(1280x800) - Page: 1
Wide screen skin has just been posted. Please feel free to drop comments here.
geposted Sat 23 Oct 04 @ 1:08 am
NrgPlyrPRO InfinityMember since 2004
Can you make it a 1024X760???
geposted Sat 23 Oct 04 @ 1:40 am
DJRobyPRO InfinityMember since 2004
Very nice skin DJ Manixx!!
Im anxious to try it out but i seem to have problems activating it on VDJ. Is there something that I am missing when installing this skin? The error message im getting is "invalid skin file". Ive saved it to skins folder but unfotunately its not working. I would really appreciate anyones input.
Great work!!
geposted Sun 24 Oct 04 @ 1:48 am
How do you get the auto scratch to work ?
geposted Sun 24 Oct 04 @ 3:01 pm
claxPRO InfinityMember since 2004
1) Launch VDJ and go to the setup.
2) Go to the lugins section and select what kind of autoscratch you want to test.
3) Select a skin with the autoscratch button or create a shortcut for it.
4) Activate autoscratch and ... scratch.
geposted Sun 24 Oct 04 @ 4:08 pm
Ditto!!! Thanks Clax.
geposted Mon 25 Oct 04 @ 12:59 am
My problem with the (1280 x 800) is that I cant scratch with channel 2? do you think that its actualle my software? I dont 'cause the other skins scratch normally. Any ideas?
geposted Tue 26 Oct 04 @ 10:17 pm
fmooijPRO InfinityMember since 2004
I noticed there is an update of the Floop skin to V3.1
I am using the skin which is perfect for a long time, however in 1280 x 800.
Are you going to post this version also??
many thanks,
freek
geposted Sun 13 Nov 05 @ 11:18 am
I'm working on updating all other screen resolutions.
geposted Tue 22 Nov 05 @ 2:33 pm
Thanks in advance.
geposted Wed 23 Nov 05 @ 11:20 pm
I'm just thinking it would be better to have the level sliders close to the middle (less mouse movments).
Sure Clax
geposted Tue 06 Dec 05 @ 6:53 pm
iamtonyPRO InfinityMember since 2005
can someone tell me where i can download this skin. i can only find the version with the smaller resolution. thanks!
geposted Sat 25 Feb 06 @ 3:55 pm
never mind, i found it.
geposted Sat 25 Feb 06 @ 4:27 pm
HaywardPRO InfinityMember since 2005
Where did all the Floop skins go?
They are no longer on the skin page.
geposted Tue 28 Feb 06 @ 4:41 pm
I tried to update the skin to v3.4 and poof everthing is gone.
geposted Mon 06 Mar 06 @ 4:48 am
pupileHome userMember since 2006
rember me please
geposted Fri 17 Mar 06 @ 12:28 pm
He Marnix,
I am still using the Floop 1289x800 without video mixing etc.
I hope you can help me how to edit it it.
What i want to modify/add is just in BPM field, the star if the bpm analyses has typed the number as a good for auto mixing.
In this way i know when i can do half automix. I only turn down bass and treble during fading.
Or i will mix total manually. Set fade in the middle and level down the playing number and start the new number.
freek
geposted Mon 10 Apr 06 @ 10:40 am
Anyone using the Floop skin with video. I am having problems with the video in the center of it jumping with white lines in it. I wanna use that skin but it isn't working for me. I tried re-downloading it and it still didn't work correctly. Brian
geposted Sat 22 Apr 06 @ 12:18 am
Which resolution version are U using?
geposted Mon 24 Apr 06 @ 3:40 pm
77%
