Forum: VirtualDJ Skins
Topic: FLOOP DJ(1280x800) - Page: 2
1024X768, I just posted under this topic cause I thought the person made both versions and can help me. Thanks Brian
geposted Wed 26 Apr 06 @ 10:24 am
Workin on it.
geposted Thu 27 Apr 06 @ 5:45 pm
Thanks. Brian
geposted Tue 02 May 06 @ 1:09 am
Funny thing is that this skin 1024X768 works on my other machine without external video enabled, I don't know if that will help you or if you know of a bug. Thanks Cheers Brian
geposted Sun 04 Jun 06 @ 9:55 am
iamtonyPRO InfinityMember since 2005
can someone PLEASE tell me how to resize the beat scrolling window. i shrunk it and i have no idea how to get it back. thanks!
geposted Tue 06 Jun 06 @ 4:06 am
listen2PRO InfinityMember since 2005
did you edit the XML or did you just change the size the zoom size when using the skin?? If you didnt touch anything in the XML then all you should have to do is click on the waves with your mouse and scroll the wheel.
geposted Tue 06 Jun 06 @ 4:13 pm
