UGH!!! OK so I have been waiting FOREVER for the MixLab 2.0 skin.. now it's finally here and I get the error mentioned by a few others...
"Invalid skin file (error line 0 in the xml)"
OK so in an attempt to fix it myself this is what I have done
1) Upgraded from rev4 to rev5
2) Downloaded and Installed the skin file again
3) Rebooted my computer
4) I also messed around with the files in the ZIP archive.. replacing the 2.0 xml file with the 1.3 xml file and I was able to actually get the 2.0 skin to launch. The skin looks great until I attempt to use it HaHa then when I mouseover certain aspects of the skin I see the old 1.3 stuff instead
5) I tried opening up the 2.0 xml file in Dreamweaver to see if I could maybe just edit line 0 but there is NO line 0.. it begins at line 1
How can there be an error in line 0 if there is no line 0???
PLEASE can someone help????
Thanks
Thanks
geposted Fri 09 Nov 07 @ 7:21 pm
Well two things are crossing my mind at the moment..
1. The VirtualDJ Logo which is allways included in the skins, does it causes general failure (error in line 0)? I haven't seen a Cue skin but it should have a Numark logo also?
2. Does your video card and monitor support 1280X800? If yes, maybe you should try to change your resolution before loading the skin.
Anyway it works for me ok. Great skin
geposted Fri 09 Nov 07 @ 10:14 pm
OK I kinda got it working.. in the OLD 1.3 xml file.. lines 13 thru 16 look like this:
<logo>
<size width="36" height="18"></size>
<pos x="24" y="5"></pos>
</logo>
but in the NEW 2.0 xml file.. lines 13 thru 16 look like this:
<logo>
<pos x="32" y="10"></pos>
</logo>
So what I did was change the NEW 2.0 xml file line 14 to match that of the OLD 1.3 xml file line 14.
I am now about to launch and use the 2.0 skin but take a look at how the logo kinda overlaps where it should not :-(
Any ideas how to fix?
<logo>
</logo>
<logo>
</logo>
![](http://i90.photobucket.com/albums/k277/MikeyShine/MixLab20.jpg)
geposted Sat 10 Nov 07 @ 1:06 am
Hi djdraco1,
Nice to see your sorted with your skin of chioce, told you if you posted it in the skin page you'll get help.
DJ format is Da Man.
Jimmy b
geposted Sat 10 Nov 07 @ 6:49 pm
I had the same issue......I'm running a 19" at 1280x960 60hz......at one point I could not open vdj; got the line 0 error. I've gotten this in the past.....I rebooted and all skins seem to work....
This is wild....so I've opened and closed VDJ a few times.....
Just opened it(I had last closed it when it was on the Vmix 5.3 skin.....It opened to the default skin...tried to change it back to the Vmix skin...line error 0
I was able to change to the DAC 4.3 skin
Mix Lab 2 skin - error
Mixlite 1.0 OK
Turntablist OK
default- fine....
All these skins worked when i rebooted.....
Mixlite 1.0 OK
Turntablist OK
default- fine....
geposted Wed 21 Nov 07 @ 1:12 am
Interesting...i re-adjusted resolution on the pc...dropped to 1152x864...went back to 1280 x 960.....The skins that were working previously would not open.....
Rebooted ----- Everything is Fine
So repeated closing and re-opening appears to aggravate the problem; rebooting seems to cure it....
geposted Wed 21 Nov 07 @ 1:32 am
Can anyone provide insight as to why this is occurring
Thanks
Thanks
geposted Fri 23 Nov 07 @ 2:26 pm
Thanks
Thanks
What version of WINDOWS are you using? I had a problem whilst using XP MCE2005 where ANY compressed skin would not load... if I extracted the skins from the .zip they loaded without any problem...
Maybe this resolve will help you too...
DJ Mykel
geposted Fri 28 Dec 07 @ 1:19 am
thanks Dj Mykel
i to was haveing the "Invalid skin file (error line 0 in the xml)" problem
i did what you sugested and now it works fine everytime
thanks again Aubs
thanks again Aubs
geposted Fri 28 Dec 07 @ 11:38 am
I had the same problem yesterday eve.
What I did: Reload the mixlab, active the mixlab, restart the laptop and it works again ;-)
geposted Thu 10 Jan 08 @ 8:01 am
DJ Mykel
Thanks
Thanks
DJ Mykel
Odd i use MCE2005 and i have no problems loading skins but i did have audio glitches at one point where i noticed unzipped skins ran smoother.
geposted Thu 10 Jan 08 @ 12:20 pm
I unzipped the ones I had issues with...they all seem to be working......Thanks......
btw..using XP home
btw..using XP home
geposted Wed 16 Jan 08 @ 5:46 pm
There is as well a possibility as if you work in the xml by means of the pad and if the skin was created with the software C ++, the skin will give error, has the line 0
solution, maybe that if you have to work the xml, him(it) made with C ++ (free)
a+
a+
geposted Wed 16 Jan 08 @ 7:56 pm
i have the same problem
i have windows vista
i have done all yoyr solutions but nothing is happens
please tell me what else i can do!!!!!
geposted Wed 28 Jan 09 @ 3:22 pm
Go to My Computer/My Documents/Virtual DJ/skins delete all of the skins except the default skins. Then try to re-open VDJ. See if that helps. Also, you should register your software here.
geposted Wed 28 Jan 09 @ 4:01 pm
thanks very much
TearEmUp you are the best
i did all that that you said to me and the programm works again
thanks again
thanks again
geposted Thu 29 Jan 09 @ 9:00 am
CHANGE!!!
it´s
<logo>
<size width="36" height="18"></size> <--------------------I NOT
</logo>
for
<logo>
<size width="80" height="20"></size> <---------------------------I YES
</logo>
it´s
<logo>
</logo>
for
<logo>
</logo>
geposted Thu 29 Jan 09 @ 9:40 am
johnakozzz wrote :
thanks very much
thanks again
thanks again
Glad it worked for you.....
geposted Thu 29 Jan 09 @ 11:01 am
I cannot open pcdj ,when I try to open it a message comes up ;invalid skin file <error line %i in the XML>.As I am a beginner I am stumped as to what to do,can you help me in simple terms PLEASE. I have tried going into skins and eliminating one at a time but still no joy so have reinstated skins. I have a sony vaio vgn-NR11M/S running on VISTA home premium.
geposted Thu 26 Feb 09 @ 8:48 am
You using PCDJ or Virtual DJ??
geposted Thu 26 Feb 09 @ 3:11 pm
