Does Virtual DJ Have the TRAIN HORN effect????????
geposted Mon 12 Nov 07 @ 2:52 pm
Please dont double post in more than 1 topic.
geposted Mon 12 Nov 07 @ 9:07 pm
You can rip that sound for vengaboys-we like to party if you want to.
geposted Mon 12 Nov 07 @ 9:10 pm
rip the sound, i think that might sound a little cheesy. Shouldnt this program allow u to find and download audio effects with no problem. to be honest most the audio effects i've heard are just ridiculous who in their right would use those effects. "Push Push Push" "This This This" "Pump It Up" "Siren".
geposted Wed 14 Nov 07 @ 1:03 am
Well you can always try and find your own to effects to use.
There are more effects and samples for you to use on the website but you have to be a registered user to download them.
Jimmy b
geposted Wed 14 Nov 07 @ 1:13 am
What you continue to call effects are actually samples. Samples are clips of a sound that you would play in a 1 shot jingle or loop. Most clips are usually taken straight from existing 'tracks'. Any sample can be of the mp3 format and be loaded for play using the sampler.
Since you already have this thread else where I will lock this one. And please don't double post. And if you purchase the software, I think you will become more appreciative of what you gain access to. The samples that come with the demo are intended to demonstrate the capabilities not necessarily be the most appealing for real world use.
geposted Wed 14 Nov 07 @ 12:02 pm
