Forum: VirtualDJ Skins
Topic: Problem re-sizing skin....
I am trying to resize my skin to fit my resolution. Everything says it is fine, I zip the file nd it is there when I go to skins in virtual DJ. When I click on the skin it is gicing me an error.
Invalid skin file (Error line 0 in the xml)
What the hell does this mean. Can anyone help me........
geposted Thu 20 Dec 07 @ 2:53 pm
listen2PRO InfinityMember since 2005
when you resized the skin somethings shift and come out of place, line 0 is in reference to the logo, it can not overlap anything, it needs it own space. You can open the BMP in paint and choose a spot for the logo, in the bottom of paint it will give an X & Y postion, you then can edit the XML lie for the logo to match those positions.
geposted Thu 20 Dec 07 @ 3:32 pm
Thank you, I found the one I want in the size I need on the skins page.
geposted Thu 20 Dec 07 @ 3:51 pm
jimmy bPRO InfinityMember since 2007
Which one have you gone with then Jim.
Jimmy b
geposted Thu 20 Dec 07 @ 6:32 pm
I got the one with the internal mixer, and I really like the turntableist one.
geposted Fri 21 Dec 07 @ 2:37 pm
did you get it to work? tell which that is still not working and i'll fix it.
geposted Sat 22 Dec 07 @ 9:20 pm
They are working fine now. Thanks
geposted Sun 23 Dec 07 @ 5:56 pm
