thanks for your hardwork gonna have a go now :)
geposted Thu 17 Jan 08 @ 1:02 pm
Hope it will went well for ya;)
N do post result or u have any problem just ask.
geposted Thu 17 Jan 08 @ 1:04 pm
See when connecting the mixer to the mk2 do I still need the mixer connected to the cdj ?
geposted Thu 17 Jan 08 @ 1:09 pm
No Need.. Just follow the illustration;)
geposted Thu 17 Jan 08 @ 1:15 pm
Thanks for that spinnaJ,
I'll need that diagram soon, as I will be setting up my 1210's and TCV's up to VDJ when they in stock for us in England. Just one little question though, Where would you attach the grounding cable of the decks, on the herc or on the mixer????
Or doesn't it matter???
Jimmy b
geposted Thu 17 Jan 08 @ 1:41 pm
ok I have now set it up correctly but when I open virtual dj and go into the settings and click auto - config the program just gets a big error and crashes. the error is the one that says do u want to try and recover
geposted Thu 17 Jan 08 @ 1:42 pm
Jimmy b
Jimmy b
I ground it at the external mixer..
geposted Thu 17 Jan 08 @ 1:54 pm
Have u ticked CD instead of vinyl?
Does this happen everytime u click auto config?
make sure the asio is on (before u start vdj check on herc control panel)
try performances setting, make latency to auto n set to fastest (move this up one by one n see ur system limit).
So I keep on vinyl. Yes it crashes when I click cd but when I click vinyl then clcik auto config and it stays at 0%
geposted Thu 17 Jan 08 @ 3:38 pm
Thanks, spinnaJ mate.
Jimmy b
geposted Thu 17 Jan 08 @ 4:47 pm
If u using tccd, do use the cd options. N post ur crash guard txt here after u have the crash.It be located at virtual dj folder at my document.Thnks.
geposted Thu 17 Jan 08 @ 10:21 pm
CRASHGUARD
date=801181206
version=5.0-Trial
build=500
thread=Main
address=0043caeb
ins=f3ab8b7c
excode=c0000005 (1,6363f00)
date=801181206
version=5.0-Trial
build=500
thread=Main
address=0043caeb
ins=f3ab8b7c
geposted Fri 18 Jan 08 @ 6:06 am
ok thks.. be back to u.
R the programe still crash?
geposted Fri 18 Jan 08 @ 6:52 am
yes it does
geposted Fri 18 Jan 08 @ 8:11 am
ok i see u r using the last demo.. do try the latest ones here n post the result.
http://www.virtualdj.com/download.html
geposted Fri 18 Jan 08 @ 12:29 pm
Crash ID=0043c2e8 (date=801181912, version=5.0 rev.4 Trial, build=504, thread=Main, dump=f3ab8b7c, excode=c0000005 (1,62a9240))
geposted Fri 18 Jan 08 @ 1:12 pm
Can you post screenshot of the timecode config menu in advanced mode with your timecode playing?
Do u use consumer tccd or pro tccd? Try to use the pro as it is -13db n urs is pioneer which tend to have high output.
Have u lower down ur herc volume on the herc control panel or the unit itself? Maximum output may distort the signal.
geposted Fri 18 Jan 08 @ 3:13 pm
ok I am using the pro tccd and I have lowered the volume done on the her control panel and the unit
http://img172.imageshack.us/img172/6728/testba9.jpg
geposted Fri 18 Jan 08 @ 3:23 pm
It should be OR not AND. Need to compensate either one.. N is the screenshot u posted r this u already play ur timecodes? Seem u on pause. Could u play the timecode n without auto config n post again. I want to see the wave pattern.
Btw while u change the setting, do u press auto config n crash again.
Sorry if this require a bit of werk as i need to know ur signal.
geposted Fri 18 Jan 08 @ 4:04 pm
http://img409.imageshack.us/img409/6435/testva2.jpg
geposted Fri 18 Jan 08 @ 5:09 pm
