Hello fellow DJ's, I have been having this problem with VDJ 5 rev6, I suddenly no longer have access to any of my sound effects.
They are listed on the Effects screen, but are non-operational. I cannot access any of them, even though the .dll files are all in the effects folder.
If I try the vocals+ effect, it completely crashes the program.
It crashed on New Years eve in the middle of a mix, which was VERY troublesome.
I have ran a Crash Guard report, but nothing shows up on it.
I have also un-installed and re-installed VDJ now 5 times, it is no different. They still won't work.
Anyone have any ideas?!?
Any help would be appreciated!!
THANKS!! and HAPPY NEW YEAR to all!
geposted Thu 03 Jan 08 @ 12:57 am
Did they work in 5.0 r5??
geposted Thu 03 Jan 08 @ 1:01 am
I had the same issue with some of the plug inns, I just delete the non working ones, for me was a strange flanger not the default one and some other effect, I do believe some of the effects need to be redone to be compatible with v5
geposted Thu 03 Jan 08 @ 1:07 am
Yep, happened to me. I installed the LFO from this site and it showed up as a dll and in the effects section of vdj. But when I went to use it, it was blank. So, I deleted it.
geposted Thu 03 Jan 08 @ 12:25 pm
Yes, they all worked in rev 5. I haven't downloaded any new plugins though! They are the ones that came packaged with it!!
The only effect that still works is flippindouble.... and vocals+ is still crashing the program.
Here's a copy of a crash report I just took....
Crash ID=01b9a778 (date=712261816, version=5.0 rev.6, build=506, thread=Main, dump=8f058ea7, excode=c0000005 (8,1b9a778))
Crash ID=01b47978 (date=712311722, version=5.0 rev.6, build=506, thread=Main, dump=8f058e79, excode=c0000005 (8,1b47978))
Crash ID=01c906d0 (date=712312130, version=5.0 rev.6, build=506, thread=Main, dump=8f05e606, excode=c0000005 (8,1c906d0))
Crash ID=01bfe760 (date=712312131, version=5.0 rev.6, build=506, thread=Main, dump=8f0576e7, excode=c0000005 (8,1bfe760))
Crash ID=01be53a0 (date=712312131, version=5.0 rev.6, build=506, thread=Main, dump=8f05b653, excode=c0000005 (8,1be53a0))
Crash ID=01bca1b0 (date=712312153, version=5.0 rev.6, build=506, thread=Main, dump=8f05c6a1, excode=c0000005 (8,1bca1b0))
Crash ID=01bf13a0 (date=712312157, version=5.0 rev.6, build=506, thread=Main, dump=8f05b613, excode=c0000005 (8,1bf13a0))
Crash ID=01bed8c0 (date=712312202, version=5.0 rev.6, build=506, thread=Main, dump=8f05d6d8, excode=c0000005 (8,1bed8c0))
Crash ID=01bde3a0 (date=712312208, version=5.0 rev.6, build=506, thread=Main, dump=8f05b6e3, excode=c0000005 (8,1bde3a0))
Crash ID=01ddd6d0 (date=801010229, version=5.0 rev.6, build=506, thread=Main, dump=8f05e6d6, excode=c0000005 (8,1ddd6d0))
Crash ID=03609be8 (date=801031335, version=5.0 rev.6, build=506, thread=Main, dump=8f05fe9b, excode=c0000005 (8,3609be8))
Crash ID=01dd33a0 (date=801031336, version=5.0 rev.6, build=506, thread=Main, dump=8f05b633, excode=c0000005 (8,1dd33a0))
geposted Thu 03 Jan 08 @ 2:39 pm
Is it on XP or Vista?
Did you change something on your computer? A Windows update ? A software removed?
geposted Fri 04 Jan 08 @ 5:03 am
Yeah, for me the only ones that are working are flippin double, TK Filter V2 and Vocals+. I removed the .xml file but nothing changed. What I find interesting is that before this update 128 Protection error, all of my effects were working w/o problems...but now, they are not active except for the 3 mentioned.
geposted Sat 05 Jan 08 @ 10:21 pm
