Is it possible i can get a copy of 5 rev 5? That one works the best for me so i want to stick with it. I have that version on my laptop and it works flawless i need a copy for my home cpu!!
geposted Wed 26 Mar 08 @ 8:47 am
Submit an e-ticket here http://www.virtualdj.com/contact/ someone will contact you about previous versions.
geposted Wed 26 Mar 08 @ 9:33 am
Also try to save these install files onto a cd or jump drive, it makes it easier on yourself if the need arises to reinstall.
geposted Wed 26 Mar 08 @ 2:37 pm
is there a thread on how to do this?
geposted Thu 17 Apr 08 @ 11:05 pm
All I've done, is to create a Folder in My Docs, called it "Special Folder" In this folder I have VirtualDJ rev5, rev6 and rev7, also I have the 2007 and 2008 driver package's for my mk2.
All you have have to do is, once you've downloaded the new rev or driver, before opening it and running the setup is to copy/paste it to a location on your choice, I save mine in that speciel folder as mention above.
Easy really.
geposted Fri 18 Apr 08 @ 6:47 am
Then from there you can burn that folder to a cd. I do this every once in awhile with all the plugins, and skins I use in case of a crash.
geposted Fri 18 Apr 08 @ 1:36 pm
