i just recently bought a brand new laptop with great specs
quad core processor, 3 gb of ram,etc an di installed the vers 5 virtual dj and i notice the waveform display seems a little different. no matter what skin i use it seems to be a slight bit jumpy or not consistent. i cannot explain it it just seems to not flow as normal from the vers 4.3 way.
anyone can you please help
thank you
regards
kp
thank you
regards
kp
geposted Tue 13 May 08 @ 11:23 pm
Test without the keylock on both decks to see a difference
Or try to adjust your latency in the software
geposted Wed 14 May 08 @ 8:42 am
thanks for the advice but i tired it and no change
it could be my monitor and maybe its just the glossy screen and laptop 15.4 inch monitor tha ti smakin me "think" its jerky.
please anyone can you give me further tips
also
if i wanted to downgrade back to 4.3 is that easy to do or would i have to blow it all out and uninstall everything and start from scratch.
for some reason i think i like 4.3 better anyway.
thank you so much
regards
kp
also
thank you so much
regards
kp
geposted Wed 14 May 08 @ 1:08 pm
for kicks try a skin that is not is a zip file. unzip it and then open that in vdj, see if that might make a difference.
geposted Wed 14 May 08 @ 3:48 pm
I would suggest switcing to manual beatlock verses Techno/House.
geposted Thu 15 May 08 @ 1:08 am
