Last night for the first time I had 2 crashes where the smiley face went up but wouldn't recover, it just shut down.
Here is the report:
Crash ID=08a6673c (date=805212244, version=5.0.7, build=507, thread=Main, dump=c74024ff, excode=c0000005 (1,3c))
Freeze (date=805212244, version=5.0.7, build=507, thread=Scan)
Crash ID=08a6673c (date=805220055, version=5.0.7, build=507, thread=Main, dump=c74024ff, excode=c0000005 (1,6d0099))
The first time I clicked on something in the playlist on the right and the second time I was clicking on my computer in the browser on the left.
Please let me know what happened as I said I have never had crashes before (that weren't my fault). The thing different about the night was that I installed JPBOGGIS's new mapper for the Denon, I love that mapper by the way.
System:
Toshiba
Windows XP
CPU T2400 @ 1.83GHz
1.84Ghz, 2 GB Ram
Here is the report:
System:
Toshiba
Windows XP
CPU T2400 @ 1.83GHz
1.84Ghz, 2 GB Ram
geposted Thu 22 May 08 @ 9:52 am
Does anyone know what these crashes are related to?
geposted Mon 26 May 08 @ 9:23 pm
Glad i am not the only one. Sunday i had a similar report. The first crash in a while. The smily face would not react the software froze, reminicent of the needle being stuck on granny 78's :). Unfortunatley my backup was'nt with me as my confidence in VDJ was getting to the point that i chance leaving it behind for the first time, what a fool i am , although i don't think the software was to blame on this occasion for my crash, i hope ?
I checked the report on the system log of which pointed to VDJ however i believe it was a memory overload to blame for mine i will place the crash report on site for diagnosis later today
geposted Tue 27 May 08 @ 5:16 am
These crashes are indeed linked to the Jpboggis's HC4500 mapper during automix
geposted Tue 27 May 08 @ 7:45 am
Please can the team advise on this report, thank you.Crash ID=0040d88e (date=805252152, version=5.0.7, build=507, thread=DSOutputSafeDual, dump=8b048add, excode=c0000005 (0,26e3a000))
geposted Tue 27 May 08 @ 9:06 am
During automix with master tempo?
geposted Tue 27 May 08 @ 9:14 am
Yes automix was in play on deck A , deck B was in play at the time.
geposted Tue 27 May 08 @ 9:33 am
Better send JPBoggis a pm regarding this Issue, you've probably found a bug in his new mapper for the HC 4500, in order for him to put it right.
geposted Tue 27 May 08 @ 9:54 am
Hi jimmy
I don't use the HC4500 sorry for the confusion. Just pointing out that i had no issues for a while and then crash. No changes to my hardware so had to discount that theory. Thought the crash report would suggest a memory issue although on the system i was using has plenty.
geposted Tue 27 May 08 @ 10:44 am
There appears to be a bug with automix when using the mapper that didn't show up during beta testing.
A fix should be available soon, but in the meantime, please either avoid using automix or temporarily disable the mapper while it's in use (Effects -> External Devices -> HC4500 -> Mapper Enabled button.)
geposted Tue 27 May 08 @ 12:43 pm
chriso710 wrote :
Hi jimmy
Your crashguard report is not linked to HC4500
geposted Tue 27 May 08 @ 4:40 pm
Hi Djcel
I did state that i don't use a HC4500 just wondered what the report meant . Thank you for replying so quickly :)
geposted Wed 28 May 08 @ 4:33 am
