I've posted asking for help in the hardware discussion, but realizing that not everyone checks that, I'm hoping for help here. I'm using American Audio CDI-500's, Virtual Vinyl, and a laptop with more than the minimum specs. I'm having an issue using timecode cds. I've tried adjusting the gain, I've tried using professional signal timecodes, I've done auto-config. Yet, when I adjust the pitch on my players so I can mix, I get digital "problems" like the signal is dropping out. Watching the timecode quality as I do this, the quality drops to coincide with the problem. Any suggestions?
geposted Sat 28 Jun 08 @ 3:28 pm
What is your laptops specification , the more details the better.
i would advise you to set on config > performances latency to auto as a starting point.
Kind Regards
Simon Bangs
Numark Computer DJ Product Specialist
Numark Alesis Europe Ltd
Skype : NumarkSi
Kind Regards
Simon Bangs
Skype : NumarkSi
geposted Sat 28 Jun 08 @ 5:40 pm
It is set on Auto.
Gateway, Vista, Dual Core 1.63 GHz, 3GB Ram, 354MB dedicated video memory.
geposted Sat 28 Jun 08 @ 6:23 pm
Could you please take a screen shot of your time code signal ?
It if it is large i would advise you to download the professional signal from this site.
http://www.virtualdj.com/products/timecode/cd.html
Kind Regards
Kind Regards
Simon Bangs
Numark Alesis Europe LTD
Skype : Numarksi
Kind Regards
Kind Regards
Simon Bangs
Skype : Numarksi
geposted Sun 29 Jun 08 @ 2:47 pm
Only problem with taking a screenshot, is that the quality drops and goes back and forth to 100%. I've tried using the professional signal as well, and that didn't change the problem.
geposted Sun 29 Jun 08 @ 3:17 pm
I appreciate everyone's help on this. But when I called Numark today to try and work through the problem all at once, they told me that my players are probably the problem. I have American Audio CDI-500's, and apparently they aren't "professional" players. However, my Denon dual deck had some of the same problem, though not as bad. right now I'm weighing my options, because I don't have $1500 to drop on a pair of Pioneers. If anyone has another suggestion or a possible fix, I'm up to try it (because I would prefer to use something similar to VDJ), otherwise I'll have to look for another program or stay Analog.
geposted Mon 30 Jun 08 @ 5:11 pm
burn the smaller cdj timecode signal on this website
check your VV inputs... make sure the box is lines (mine moves to phono somethings in a bag)
remember to constantly repeat the track (my signal is funky at 11 minutes.... i just turn it back and i get signal again)
geposted Mon 30 Jun 08 @ 8:15 pm
PearlEx97 wrote :
Only problem with taking a screen shot, is that the quality drops and goes back and forth to 100%. I've tried using the professional signal as well, and that didn't change the problem.
I am more interested to see the waveform if you could take a shot of this that would be great.
I dont think that those players are ideal but it should not be a problem if we can get your signal correct.
Best Regards
Simon Bangs
Skype : NumarkSi
geposted Tue 01 Jul 08 @ 1:59 am
Like Skyfxl said those players should work. I dont know how familiar you are with VirtualDJ/Cue but when using timecode its not a simple plug in and play setup. I am not bad mouthing the software at all so dont take me wrong but it takes alot of tweaks and troubleshooting to get everything set just right. Once you do have things set right your good to go. I wouldnt go out and buy any other equipment just yet.
geposted Tue 01 Jul 08 @ 10:11 am
Simon, I will work at getting the screen shot of the waveform.
As for the box, it's on line input, and I've used the smaller professional signal from the site, and it doesn't change the problem.
I realize that timecode is not simply a plug and play, but I've adjusted everything that I've been suggested to adjust, and I've done auto configs, done config setups as suggested in other parts of the forum for people who had problems. After messing with it for so long I called Numark in the US to get help, and Matthew pretty much told me it was my players. Considering the system working on my friend's Pioneers, I'm tempted to believe him.
geposted Tue 01 Jul 08 @ 2:01 pm
Ok... I was having problems getting this whole BB Code to work, because when I clicked the + sign it went minus, but nothing showed up below it. Anyway, here is a link to a picture of the timecode quality and waveform. Again, the biggest problem for this happens when I am changing the pitch. I have tempo lock OFF and only the pitch slider is on.
http://i308.photobucket.com/albums/kk349/PearlEx97/TimecodeQualityproblem.jpg
geposted Tue 01 Jul 08 @ 10:53 pm
There you go PearlEx97
By the look of it to me, it looks like you have a slightly to "loud" timecode signal, also try the timecode with the Software RIAA Preamp option checked. I've had a problem with signals fluctrurating when I first set up my timecodes (TCV) till I checked that.
geposted Tue 01 Jul 08 @ 11:22 pm
Here are the links for a few different screen shots I took based on the suggestions by Jimmy b
First is the Professional Signal with the Preamp checked
http://i308.photobucket.com/albums/kk349/PearlEx97/Professionalsignalandpreamp.jpg
Original timecode with preamp checked
http://i308.photobucket.com/albums/kk349/PearlEx97/TimecodeQualityproblemwPreamp.jpg
And finally timecode with professional signal
http://i308.photobucket.com/albums/kk349/PearlEx97/TimecodeQualitywProfessionalsignal.jpg
geposted Wed 02 Jul 08 @ 9:18 am
Well my suggestion, didn't really work for you mate
geposted Wed 02 Jul 08 @ 9:41 am
So... any new ideas?? Only other idea I've received so far was the clean the RCA plugs of my players. That didn't fix it either.
geposted Sun 06 Jul 08 @ 11:47 am
First thing that you have to know: "Software RIAA preamp" is only for vinyls. In clear, understand it like the difference between Phono and Line.
So with the CD, you have to uncheck it.
Then I would say to verify the USB transfert with the tool "DPC Latency Checker" ©Thesycon
http://www.thesycon.de/eng/latency_check.shtml
=> disable internal webcam, ethernet, wireless
geposted Sun 06 Jul 08 @ 4:37 pm
Will be checking the USB transfer tonight.
As for the others, the checking of the preamp, was just an attempt to fix this problem. When the problem first arrived and other than the one attempt to fix it, it's been unchecked.
Webcam, ethernet, wireless are all off.
geposted Mon 07 Jul 08 @ 2:55 pm
Ok, so here's a new one for you all. As you can see I've had multiple problems getting Virtual Vinyl to work right.
So I borrowed my buddies Serato box to do a mixshow for a local radio station. After I was done with the mixing, just for the heck of it, I opened Virtual Vinyl to see if Serato would control Virtual Vinyl. As stated in other parts of the forum I knew it was supposed to, but considering my problems I wondered.
Not only did it control the program, the problem I've had since day one that I haven't been able to fix, was no problem. The program worked great, like it was supposed to. From that would it be possible to deduce that the problem was within the Virtual Vinyl box?
Your thoughts are appreciated.
DC
DC
geposted Fri 11 Jul 08 @ 3:54 pm
