Forum: VirtualDJ Skins
Topic: how do i edit mac skins?
or if I buy the full version.. will there be other mac skins available for download? I want to disable computer-aided mixing, when i want, to help me learn how to mix. thanks. If someone could tell me how to edit the default skin, that would be great... on pc its too easy. cheers
geposted Sun 29 Jun 08 @ 10:52 am
JeremKPRO InfinityModeratorMember since 2004
Nearly all skins for PC are compatible with Mac when you buy the full version.
I wrote nearly, because not all skins have been made available with a dmg installer.
But in any case, if you download the skin with a PC or in bootcamp, you will then be able to use it in VDJ for MAC.
geposted Sun 29 Jun 08 @ 1:13 pm
sbangsPRO InfinityMember since 2004
You need to purchase the full CUE or VDJ.
geposted Sun 29 Jun 08 @ 1:48 pm
not true..suckup. 'error line 0 in xml' when pc skin chosen, or when default skin unzipped and re-zipped. With the PC demo this was not the case. I doubt this has to do w/ registration. Don't know weather to get the pc or mac version. Do I get one install per reg? or can i install on mac and pc?
geposted Sun 29 Jun 08 @ 3:16 pm
spinnaJPRO InfinityMember since 2004
Once u purchase the pro version, u can installed both mac n pc version both at one time. (1 mac + 1 pc)
geposted Sun 29 Jun 08 @ 4:22 pm
You cannot get mac skins without a licence end of story.
Hope to see you as a registered user soon.
Kind Regards
Simon Bangs
Numark Computer DJ Product Specialist
Numark Alesis Europe Ltd
geposted Mon 30 Jun 08 @ 12:51 pm
thanks. I just noticed other threads that registered users had the same problems. I'd rather get the mac version then the pc version. Just wanting to know if I could work these kinks out... cheers
geposted Mon 30 Jun 08 @ 3:41 pm
You have been a demo user since 06. You will get more help and get further by purchasing a pro copy of the software. Hope to see you with us soon!
geposted Tue 01 Jul 08 @ 3:14 am
Ya seriously, it seems that half the users on this forum are unregistered users. If you want the benefits of the software then purchase the full version and stop asking why you can't do this and can't do that.
geposted Tue 01 Jul 08 @ 1:16 pm
