Just starting off, I have two denon dns3000 and a berhinger dmx300 mixer, am wanting to get virtual dj to put all my songs on a laptop and to help me mix them. I know i have to buy a laptop but what is the mimimum requirement for it , memory ect? What do i have to get as in virtual dj stuff? and also if i do get a laptop and virtual dject would i be able to put a cd in my denon dns 3000's and mix a song off the disc with a song off the laptop and for the virtual dj to help with beat matching ect
Thanks
bigspit
Thanks
bigspit
geposted Sun 06 Jul 08 @ 9:52 am
These are the min requirements for VirtualDJ
The minimum requirement to run Virtual DJ is:
* PIII 850 MhZ computer
* 1024x768 SVGA video
* DirectX compatible soundcard
* 512 MB RAM
* 20 MB free on the hard-drive
The recommended configuration is:
* PIV 3 GhZ computer
* 4.1 DirectX compatible soundcard (with front and rear separate outputs)
* 1024 MB RAM
* 200 MB free on the hard-drive
The recommended configuration to mix video is:
* Dual Core 2 GhZ CPU
* dual output ATI or nVidia video card with 1Gb of on-board memory (no integrated laptop videocard)
* 2048 MB RAM
If you wanted to use Denons aswell you would need
A copy of Virtual DJ, a 4 in and 4 out external soundcard like the Maya44, a set of Timecode CD's (which you can download from this site) and a external mixer.
geposted Sun 06 Jul 08 @ 10:17 am
bigspit.....just go for it!!!!! You gotta quite hauling all those cds around. This was my history of migrating to laptop,,,,,started out downloading every single solitary mp3 mixing program I could find on the web, most offer pretty functional demo versions that allow you to try out what "feels" right to you. If you have been djing from pro cd players and pro TT's then you may want to keep a little security blanket as you "migrate" to the laptop. ie: keep a cd player in your rack WITH the laptop, plugged in to a 4 channel mixer. I am a mobile dj now, former radio and clubs (back in the day) and used to be the guy that dared the crowd to try and stump the dj with a request that I did'nt have,,,, that meant lugging around cases of cds. Now I buzz in w/ my laptop w VDJ installed and my western digital usb 320 gig POCKET hard drive and I have faster access to the 30,000 + songs than ever before. The dj mixing capabilities are unmatched in VDJ with ANY OTHER program out there now. I reccommend the Denon 4500 usb controller to compliment your set-up. It has a fabulous sound card built in and with the JPBoggis mapper installed, makes VDJ work like a standard analog procd player....Try out the other demos, If you like maximum dj creativity, video, sampler, effects and bells & whistles, There is no other program available in US at least with this much built in. GO FOR IT,
PM me with any questions or more advise.
djtops
djtops
geposted Mon 07 Jul 08 @ 10:24 pm
