I can't believe this isn't available yet.
To truly be able to mix in the headphones without monitors, you need to be able to seperate your sources in the headphones.
I learned to mix with one ear on a can, listening to the cue'd up track and the other ear listening to the main program. Beatmatching the two. Then, bring up the new track and bring down the old track.
When split cue came around on mixers it was a Godsend. Now you could mix completely in the headphones. You didn't need an extra set of speakers to use as monitors. You could use that extra set of speakers to reinforce your sound.
Cuemix is ok. But it is hard to mix with both the cue'd signal and main mix signal in both cups.
It's much better to have Split Cue.
I know you can have Split Cue if you use an external mixer. But what if your using a Numark DJ|IO and a Total Control?
And you want to go straight into an amp?
geposted Thu 25 Sep 08 @ 12:05 am
Try with shortcuts:
Shortcut > System volume > Headphone mix
MODIFIED: Sorry ... I've understood now. I dunno how to help ya. I don't use this feature neither with external mixer. I don't like Split function.
geposted Sun 28 Sep 08 @ 4:56 am
"To truly be able to mix in the headphones without monitors, you need to be able to seperate your sources in the headphones."
Not true bro. I often spin in internet radio at weird time and i use headphones. When u are able to listen the entering track, the actual track and both tracks mixed u can do whatever you want. Assign "headphone mix" to a knob (best solution) or create 2 shortcuts (one for listen only entering track and one for listen both tracks mixed)
Hope it helps
Hope it helps
geposted Sun 28 Sep 08 @ 5:10 am
Voltron,
sorry, but I don't understand what you are saying.
If you can hear the CUE'd track in the left ear and the MAIN program in the right ear, (As is common with real dj mixers) that would be cool. No need for monitors. The reason you make it work for you is because you are also using the graphical display to mix. I want to mix in the headphones, not the screen.
geposted Sun 28 Sep 08 @ 4:35 pm
I would agree with Chris 'split cue' is and essential and basic feature, I use it all the time. It is vital especially in a booth which has terrible monitors or in a very noisy club atmosphere. Also, using your headphones properly can also help preserve your hearing, something which many DJ's take for granted until it is too late.
geposted Fri 03 Oct 08 @ 12:54 pm
ding, ding, ding... We have a winner. Split Cue, if only to protect our hearing if nothing else.
geposted Mon 06 Oct 08 @ 6:08 pm
Hi, I use an external mixer at the moment which already has split cue, but if I was going to change to something like vci300 or hercules RMX I would definately need this feature, I'm surprised that it's not already in there.
geposted Fri 10 Oct 08 @ 5:07 am
The only way to achieve such a critical function is through the use of an external mixer, you are right. Also, A RMX or Total control with a DJIO won't give you that feature.
geposted Fri 10 Oct 08 @ 4:31 pm
I think the DJ console has a knob to select split cue in the headphones.
This would be a good feature i think, even though i wouldn't use it.
geposted Thu 16 Oct 08 @ 7:24 am
Does have one?
geposted Tue 11 Nov 08 @ 12:41 am
YUP we need it..get your toolz out boyz..yall have some work to do..hehehe..
geposted Thu 13 Nov 08 @ 9:55 pm
Preach on it.
+1
geposted Thu 13 Nov 08 @ 10:10 pm
See's what I means...
I think it can be easily done in the software.
The Numark Total Control already has the ability two allow the user control of how much Main program mix he or she can hear. It's labeled "PHONE MIX".
It's not a stretch to ask that you be able to set this in the software...
This way, you can hear the CUE signal in the left ear and the MASTER mix in the right ear.
Just a couple of lines of code....
geposted Thu 13 Nov 08 @ 11:06 pm
oh so i already have it..well lets get this for the rest of the VDJ Community..
geposted Fri 14 Nov 08 @ 7:45 am
there is a pfl plug in, but i dont know if it works as split headphone, try and say me
http://www.virtualdj.com/addons/effects.html?display=all&order=smart&search=pfl
geposted Sat 15 Nov 08 @ 1:35 pm
I downloaded this plug-in and installed it. For some reason it doesn't get recognized or appear in the effects...
geposted Sun 23 Nov 08 @ 12:38 am
It was written for Virtual DJ 3.4 - it installs into My Documents\VirtualDJ\Effects, not into the Plugins\SoundEffects folder.
Whether or not the plugin will work on later versions, I have no idea!
geposted Sun 23 Nov 08 @ 5:03 pm
That's why I can't see it as an available option. Scott, to answer your query, it doesn't.
geposted Sun 23 Nov 08 @ 5:53 pm
Didn't think it would, the plugin API was changed after 3.4.
geposted Sun 23 Nov 08 @ 7:36 pm
No, you don't, bro. But hopefully, soon we both will...
geposted Tue 09 Dec 08 @ 9:10 pm
