Forum: VirtualDJ Skins
Topic: MIX station SV_04 (1024x768) VDJ 2.06- Serge - Page: 1
Serge,
Thank you for re-appearing! Great work! One question. The loop on start function seems to have 16 beats with left click and 32 on right click. Is there a way to get 2,4,8 beats too? Miss this function. Especially with songs that have a short intro.
Again,
THANK YOU
Sincerely ronny582
geposted Thu 03 Feb 05 @ 1:31 am
djcelPRO InfinityModeratorMember since 2004
Dear Serge,
I told you to stop sending me virus by mail but you carry on. Now it's finished, i have just closed your mail !! Sorry that you have decided to go until that. I was very friendly with you and i don't know why you do that.
DJ CEL
geposted Wed 16 Feb 05 @ 8:30 pm
IamAbPRO InfinityMember since 2003
Hi Serge,
I found a small bug in this skin,
at various mp3 files the beatmarks are not correct alligned to the music.
I have to select (switch the monitoring) to the other deck, and then it is aligned.
With other skins, i don't have this problem.
Best regards, Djappie.
geposted Mon 18 Apr 05 @ 12:20 pm
how do you download skins. i tryied it but it would not let me download it
geposted Tue 03 May 05 @ 7:16 pm
Go here...http://www.virtualdj.com/addons/view.html?type=skin
Find the skin that you want and click download. Most are in a .zip format. Save it to your VDJ directory in your skins folder. Open VDJ and look in config. to find the skins tab. Then activate the skin that you want.
Let us know how if it works.
MS
geposted Tue 03 May 05 @ 8:54 pm
claxPRO InfinityMember since 2004
It seems that the vertical bar at the middle of the wave display is not really at the good position (a bit too on the left).
geposted Wed 04 May 05 @ 3:56 pm
djlukHome userMember since 2003
hii serge,
Basically i would like to say that your skin is the better I have used !
I just want to know if for your next version you can put smaller buttons fr all command to let more space for the browser (for example smaller jog dial, smaller pitch fader...)
thank you very much for it
cordially
LuK
geposted Sun 08 May 05 @ 2:16 am
Why not but no smaller vinyls.
geposted Sun 08 May 05 @ 11:53 am
I have verified for the vertical bar at the middle and it's correct. I had to find a song with waveform at the beginning
geposted Sat 14 May 05 @ 3:01 pm
Strange. I really thought it was not right. Maybe I was drunk ...
geposted Sun 15 May 05 @ 11:03 am
FruitPRO InfinityMember since 2003
There IS an error...
The length of one of the two grids is incorrect. It should do a length of 1000 pixels just as the wavefome itself and as the 2nd grid. It does a length of 961 instead.
Put 1000 instead of 961 at the 18th line in the XML file and the bug shuld be corrected.
That's the Serge's skin's error.
FRUiT94
geposted Sun 15 May 05 @ 3:35 pm
Exact, Fruit - Cette erreur sera corrigée dans la version 2.1.
geposted Sun 15 May 05 @ 6:52 pm
Merci - thanks Serge.
geposted Sun 15 May 05 @ 7:01 pm
salut serge
Juste pour savoir quand la nouvelle version de ton skin va etre disponible ??
Merci
Musicalement
Djluk
geposted Tue 17 May 05 @ 3:17 am
Je pense la semaine prochaine - Cordialement - Serge.
geposted Tue 17 May 05 @ 7:49 pm
Slurp!
geposted Tue 17 May 05 @ 8:39 pm
please a 3.0 version:-)
geposted Mon 23 May 05 @ 6:46 pm
JeremKPRO InfinityStaffMember since 2004
@Serge:
Je me suis proposé sur le forum français de modifier ta skin pour y ajouter un pannel video. Je me demandais si tu veux faire ça tout seul ou si je peux apporter mon aide.
I proposed myself on the french forum to modify your skin to add a video pannel. I was wondering if you were going to do that yourself or if i could help you
Jérémie
geposted Wed 25 May 05 @ 6:16 pm
Suite à la version 3.0 de Virtual DJ, je suis en train de faire un pannel video pour la MIX station SV 04 (TITANIUM et BLACK edition) - Elle sera prête dans quelques jours.
geposted Wed 25 May 05 @ 7:56 pm
Un grand merci d'avance Serge; on peut toujours compter sur toi!
Toujours à l'affût pour rendre service.
Cordialement,
Clax
geposted Wed 25 May 05 @ 8:07 pm
74%
