Just wanted to know how to configure timecode cd's to work with cdj.
Each time i cue a trax with the cdj, and then play/stutter like i would normaly dowith normal cd's, it never goes back to my cue point.
I have Virtual Dj 5.2 with VDJ Timecode cd's and a Audio8 Dj from Native.
Could somebody please help me out.
Thanks
Thanks
geposted Thu 13 Nov 08 @ 1:30 am
Have you turned off master tempo on your CDJ's? :)
geposted Thu 13 Nov 08 @ 8:17 am
yes, I have the same exact problem and so do 2 other friends of mine. I am running a laptop with vdj 5.2.1 a pioneer cdj 100 mk3 ( the one not playing correctly at the moment) and a stanton c.304 (nothing compared to the cdjs). My other friend is running a cdj-400. when you hit cue it does not go back to the cue point. Not to mention if you play past the cue point and scratch backwards it WILL NOT go all the way back.
geposted Thu 13 Nov 08 @ 3:57 pm
Yes Master Tempo is off, also, i got the same issues as stated above, but me it's on CDJ-800. When ever i need to cue a trax i need to do it manualy in VDJ. I cant even use it properly to play only with the CDJ.
Please HELP
Please HELP
geposted Fri 14 Nov 08 @ 12:25 am
Hmmm... Have you got the pro version of timecode CD's? How does your setup window look, how do the waves go? Have you selected CD instead of Vinyl in that window?
Which mode is your CDJ? (Vinyl / CDJ)
geposted Fri 14 Nov 08 @ 6:42 am
Same issues here...
geposted Fri 14 Nov 08 @ 2:30 pm
Yeah i got the Pro CD Timecode's and got Virtual Dj Pro 5.2
The Signal is 100% and got volume/music is Working super great, it's just those cdj play back the problem, on mine at home it doesnt work, and i did 2 gig so far this week end and on both setup it wouldnt work either...
Could someone tell me how to set it up so that i can Cue/Stutter Play my trax with the cdj's....
Thanks
Thanks
geposted Sat 15 Nov 08 @ 3:40 pm
So you should add serial number to your profile and have all the extra features ;)
geposted Sat 15 Nov 08 @ 7:35 pm
What other features ?? Will that help me out in finding a solution to the cdj and timecode issue??
geposted Sat 15 Nov 08 @ 8:31 pm
What I meant was addons like plugins, sound effects, skins etc.
For Timecode issue I really can't help as I don't use them.
geposted Sat 15 Nov 08 @ 10:22 pm
Theres 100+ peps that saw the post but no one has an anwser....
Could somebody help me please...
geposted Mon 17 Nov 08 @ 1:14 am
It would increase your credibility. :) Some people refuse to help "no licence users" because they might be crack users...
Anyways: can you screenshot your settings?
geposted Mon 17 Nov 08 @ 3:39 am
The issue sounds like it's in your VDJ settings.
are you using absolute mode? relative mode, or smart mode?
Try these and see which one works for you. If i'm not mistaken, Smart mode is the one which will allow you to use TCCD's like regular DC's (make VDJ act like CD being played in cd player)
Hope this helps and if you are using Pro, Please register or purchase the software.
geposted Tue 18 Nov 08 @ 12:13 am
Yeah tried all 3 of those settings and tried also CD and Vinyl.
geposted Tue 18 Nov 08 @ 3:01 am
