Suche nach Controller Definition für MIDI - selbst gemacht
- ControllerDefinitionMIDI
- ControllerDefinitionHIDv8
- Controller Identification
- Controller ID
- Controller Developers
- Developers
- HIDimplementation
- FAQ
- Controller Not Working
- MIDI Controller Not Working
- Soft Take-over
- How to upload a Custom mapper
- HIDvsMIDI
- Controllers
- Best Midi Controller
- VideoMixing
- How do I map my MIDI controller
- ControllerMappingFile v8
- VDJscript
- VirtualDJ LE Install Guide
- Pre Post Fader Effects
- Error in ASIO or WDM Sound Driver
- Reset Factory Mapping
- 2 Sound Cards Distorted Sound
- Addons Tools
- TheLightingController with OS2L
- Mac 4 Channel Audio
- License Transfer
- Multiple Controllers
- PC Optimize
- How to Transfer To A New Computer
- Skin Define
- Skin Slider
- What hardware can I use with VirtualDJ
- os2l
- NewPurchase
- VirtualDJ8 SoundCards
- Software Comparison
- I have an issue with an Add-on
- Record Loopback
- VDJScript Examples
- Assign different actions for the same button or knob on each side of a dual-deck controller
- How to upload a Skin
- ScratchDNA
- scratch with keyboard and mouse
- QLC with OS2L
- OS2LDMX
- How do I change the mapping for a key
- How do I map a keyboard shortcut
- Crossfader Curve
- My VirtualDJ keeps crashing or my computer keeps freezing
- Minimum system requirements
- How do I change the skin or use plugins in VirtualDJ LE or Console Edition
- Is there a trial version available
- Use VirtualDJ 8 Offline
- Addons Upload
- VDJ8 Limiter
- Reset color to none
- Split panel
- Windows Connection Error
- Remote App won't connect
