i had the cracked version ov 2.6 dicided to buy the program and when i installed it saied the internal database is corrupted and it won't start...i've uninstalled all vertuals dj programs and reinstalled the full version and it doesn't help
geposted Wed 09 Feb 05 @ 4:10 pm
Try deleting the database file and restart the sw.
But for cracked versions you should write to:
www.virtualdj.com/support/e-service/
Ps: All other problems you describe in other topics are from the cracked version you had installed previously.
geposted Wed 09 Feb 05 @ 4:41 pm
Well it's clear now !! You would like to keep your previous database. You shouldn't hope that !!! The next time don't use a cracked version
Please stop creating topics for the same problem. It is very annoying to follow
geposted Wed 09 Feb 05 @ 5:03 pm
write to e-service, they'll get you all squared away!
Describe exactly what is happening, and when.
geposted Wed 09 Feb 05 @ 7:28 pm
Format your machine, reinstall windows and start fresh.
If you are a person that downloads warez, then your machine probably needs it. Lord only knows what kind of spyware/trojan/virus stuff you have in there. And no, installing warez anti-virus software is probably not a good solution.
geposted Wed 09 Feb 05 @ 8:30 pm
don -t necessary to format your hd ...just mail to support team
geposted Thu 10 Feb 05 @ 11:15 pm
