Anyone being able to do video's in mkv format with VDJ? If so, how?
geposted Fri 19 Dec 08 @ 2:56 pm
ha i figured it out..just rename it to mp4 and wha-la.
In case anyone was wondering that's how you do it.
geposted Fri 19 Dec 08 @ 2:59 pm
Even easier. Just go into CONFIG. Click on the CODECS tab and add the MKV extension.
geposted Fri 19 Dec 08 @ 7:42 pm
I tried that and it didn't work, that is when I made my post. :)
geposted Fri 19 Dec 08 @ 8:45 pm
Works for me. Can't imagine why it wouldn't work for you. You may want to double check to see if you made a typo. Also, make sure your MKV files actually have a MKV extension. Renaming every file just isn't necessary.
geposted Fri 19 Dec 08 @ 9:34 pm
thanks for the words. ill go back and retry. it would save some work going forward.
geposted Sat 20 Dec 08 @ 4:11 am
You need to install Codec pack like K-lite and it will play, just add it in codecs section.
geposted Sat 20 Dec 08 @ 5:31 am
