Ik zou eens mailtje sturen naar support van VDJ.
geposted Tue 30 Dec 08 @ 6:01 am
Daar heb ik in het begin met VDJ 5 ook last van gehad. Het geluid werd ineens keihard, dan paste je dat aan en daarna was het volgende nummer te zacht. Ik heb toen VDJ opnieuw geinstalleerd en in de config de auto gain op auto + remember gezet.
Nu werkt alles perfect.
Happy New Year
Bob
Happy New Year
Bob
geposted Tue 30 Dec 08 @ 5:57 pm
Damn, die support hier is ook (Best) waardeloos..
kijk dit:
Date: Tue 30 Dec 08 @ 8:23 pm
Message: If Im running VirtualDJ and im not touching my HerculesRMX Console, sometimes it will flush withouth im touching my controller.. how do that come?
Date: Wed 31 Dec 08 @ 6:31 am
Teamer: DJ Homeboy
Message: Sir,
Please describe to me what flush means. Do you mean crash?
Regards,
DJ Homeboy
______________________________
Internal Team
http://www.virtualdj.com
Date: Wed 31 Dec 08 @ 11:11 am
Message: Hello,
I dont know what it means in english...
I only know how to say it in dutch, I translate it with freetranslation and that says the answer was Flush.
When I play a song somtimes it will flush ( DOORSPOELEN is it in dutch... )...
Maybe you know somebody that is dutch and can translate it for you...
Thanks.
Date: Thu 01 Jan 09 @ 4:58 pm
Teamer: DJ Homeboy
Message: Crash has got to be the translation. What are you doing when it crashes/flush's?
Date: Thu 01 Jan 09 @ 6:11 pm
Message: Look, if im playing a song on Deck A, somtimes it will Be playing like 10 times faster.. uuhm.. you know if you are watching DVDS on your tv? You have a button to go to the next scene, but you also have a buten to play it faster ( Doorspoelen in dutch ) My english isnt really good, so idk if you understand me..
Ik weet niet echt hoe ik het moe tuitleggen in het engels...
Zou iemand me kunnen helpen..?
kijk dit:
Teamer: DJ Homeboy
Message: Sir,
Regards,
DJ Homeboy
Internal Team
Message: Hello,
Thanks.
Teamer: DJ Homeboy
geposted Thu 01 Jan 09 @ 12:13 pm
dj echfourel wrote :
.............een nummer blijft doorspeolen zonder dat je dat wilt.. dat is een fout van hercules.. ik ben er mee naar de winkel gegaan en daar is niks aan te doen.
Hier heb je een duidelijke opmerking over het doorspoelen. Had je dat niet gelezen?
En by the way, ik dacht dat je geluid plotseling te hard ging, vandaar mijn bovenstaand commentaar.
"Doorspoelen" is "fast forward", je zou kunnen schrijven: "Suddenly the song switches into fast forward".
Maar als 't een probleem van Hercules is, schiet je er weinig mee op.
Mvg
Bob
geposted Thu 01 Jan 09 @ 6:03 pm
Jah lekker is dat dan, is daar inmiddels geen oplossing voor bedacht of is het een hardware matig probleem?
Ik vind dat je het op deze manier niet mag verkopen...
En ik heb dat probleem dus regelmatig en dat is echt zwaar irritant als je net lekker bezig bent ken je alles weer opnieuw doen.
Nog iets, is het niet de combinatie van Virtual dj en de RMX?
of als ik bijv. Tracktor gebruik moet ik het ook hebben?
Nou ik hoop dat hier al iets voor bedacht is!
Groetjes,
DeeF
Groetjes,
DeeF
geposted Wed 18 Feb 09 @ 10:37 am
ik heb geen probleem ,VIRTUAL DJ IS THA BOMB
geposted Wed 18 Feb 09 @ 6:55 pm
Jah dat klopt hev voorheen nooit problemen gehad en nu ik de RMX heb opeen krijg ik dat probleem maar heb nu contact met die gasten.
En gaan kijken ofzo snap er echt geen zak van en dat CPU gebeuren is ook onzin want als ik het programma open heb is mijn cpu gewoon laag en tog gebeurt het :S
Groetjes,
Dave
Groetjes,
Dave
geposted Thu 19 Feb 09 @ 3:35 am
Ik zal dit probleem persoonlijk voorleggen aan het vdj team.
En flush is idd doorspoelen. Maar dan doorspoelen op het wc.
en doorspoelen op een cd speler ofzo is idd fast forward of fast play.
Als je iets niet weet, vraag het dan aan iemand. Kan nooit kwaad hé ;)
geposted Thu 19 Feb 09 @ 5:30 am
Nou ik hoop dat er snel een antwoord is want die gast van de support snapt helemaal niks van mij en hij kon geen nl want verwees hem naar deze topic...
Dit probleem is echt klote en voorheen heb ik het nnot gehad met de oudere versies...
Hoop dat iemand een oplossing weet...
Groetjes,
Dave
Groetjes,
Dave
geposted Thu 19 Feb 09 @ 10:00 am
