hi when i fist started the program i was deligthed to see that you could actualy change the key of a song.
but then i was using a standart skin wich really sucked. and found mix lab 3.1
now i have been searching for 30 minutes in that skin and you can do great thing it even had 5 eq possibilities or something
but i cant find the change key button
is it even there??
this skin is so full of options it would be kinda sad if this function was put out.
anyone?
Cheers
Matthy
is it even there??
anyone?
Cheers
Matthy
geposted Tue 30 Dec 08 @ 1:19 am
Hello djmatthy
Skins can only be downloaded by registered users.
If you have a serial number for VirtualDJ, please enter it in your profile: http://www.virtualdj.com/users/edit.html
You will then be able to download an update for mixlab on the skin download page: http://www.virtualdj.com/addons/skins.html
geposted Tue 30 Dec 08 @ 5:40 am
but here it sais i got the newest. "3.1" should probarly be 1.3 but. so download a new skin version should not be needed rigth?
it also is 1280 * 768
geposted Tue 30 Dec 08 @ 12:23 pm
if it's from an "unreliable source" please download latest free demo...
geposted Tue 30 Dec 08 @ 2:13 pm
I m still looking for a skin that will let mr change the key of a song played... can anyone help me with this?
geposted Sat 28 May 11 @ 5:35 pm
How about the default ? :)
TCmania has a key knob too, http://www.virtualdj.com/addons/11460/TCmania.html
geposted Sat 28 May 11 @ 8:20 pm
