Help, VDJ 2.03 is stopping during playback.
I can't use a newer version of vdj. 2.03 seems to be the most stable version until now.
It will stop for half a second or longer, then continues to play.
Sometimes it will stop and not start playing again.
Help.
dj@gvmusic.com
Help.
dj@gvmusic.com
geposted Thu 17 Feb 05 @ 11:10 pm
System Specs?
Your symptoms sound like a lack of ram or cpu power.
geposted Fri 18 Feb 05 @ 7:42 am
You can upgrade to 2.06 ....if you like its much smoother
Andre
Andre
geposted Fri 18 Feb 05 @ 9:50 am
tried the upgrade and still getting a pause once in a while
geposted Sat 19 Feb 05 @ 8:22 am
So now its a pause once in a while....is there a big difference from the other version.?
The performance should be better in 2.06
And yes i gig of Ram is plenty your cpu should run smoothly
Check your task manager to see if there is any altering in the performance when it pauses
Andre
Andre
geposted Sat 19 Feb 05 @ 11:43 am
try to disable parser ;)
geposted Sun 20 Feb 05 @ 10:53 am
