! Is there an easy wy to print the playlist? !
geposted Sat 19 Feb 05 @ 8:23 am
Hi,
Find your playlist (.m3u file) Open it with WordPad then print it
geposted Mon 21 Feb 05 @ 3:34 am
I'm trying to create a plugin for that. Just need more time...And my first problem is that the playlist is saved only when you close VDJ or you go to the settings , in infos section
geposted Thu 24 Feb 05 @ 2:57 pm
How ?
In infos page, there is only a "save history" button not save playlist, for the auto-created m3u playlists.
geposted Thu 24 Feb 05 @ 5:35 pm
Sorry you're right i talked about "History".
For playlist, it's more difficult but i think it's possible too with a plugin. I will have a look. If the playlist is loaded in VDJ browser for playlist, i think i can do it...
geposted Fri 25 Feb 05 @ 4:51 pm
correct me if im wrong.. but doesnt the history show the times when you first loaded the track. It would be cool if someone made a plugin to make it when the crossfader actually hit the middle the time was recorded.. would make creating cue sheets and the like a lot easier.
geposted Tue 01 Mar 05 @ 5:07 am
