Forum: Old versions
Topic: Calling all Mac Vestax VCI 100 users...
Please can you go on the "System Profiler" found in "Utilities" and tell me if your mac detects the VCI 100 as a high speed USB device or not?
Mine does not even though I think it should be. I've been having problems with my new MBP I think ever since I upgraded it to the latest firmware. VDJ does not detect the Vestax automatically like it should. I have to disable and re-enable it which is anoying. Please help.
Thanks.
geposted Thu 15 Jan 09 @ 12:09 pm
PtownDJPRO InfinityMember since 2007
Mine actually detects the unit now better then ever... I only use the port on the right side though... Hope that helps
geposted Wed 04 Feb 09 @ 9:12 am
